It is currently Fri Feb 27, 2015 11:53 pm
Post a new topicPost a reply Page 1 of 4   [ 63 posts ]
Go to page 1, 2, 3, 4  Next
 Post subject: SR20DET Datsun 1200 Ute
PostPosted: Thu Jun 12, 2008 6:47 am
There's a lot to post here (two years worth of work), so try to keep any questions until I'm done... :wink:
In case you fellas from down under and in Japan didn't know, we never got these cool cars here in the US. But my friend Steve managed to get one here.
And he's putting a monster SR20DET in it. Notice the big BLITZ front-mount too...
He's aiming for 400hp, so no Datto rear end would do...
Putting in a narrowed Ford 8.8" with a locker:
Mocking up the mounts for the diff lateral links
Same thing, welded in and undercoated
Other side
Lateral link mounts on diff
Other side
Custom panhard rod
New flat face headlights fitted
PostPosted: Thu Jun 12, 2008 6:50 am
Adjustable coil-overs fitted
Rear overall view, and yes, that's a BIG diff (from a Mustang FYI)
Turbo manifold, view from the bottom (as that's the only way to see it)
The car picked up a few scratches and dings while fitting the new rear axle so Steve decided to two-tone the ute.
Back from the paint shop (for the 3rd time!)
Shot of the intercooler. It won't be visible at all when the truck is done.
And he should be able to fit some decent rubber under there... May be tubbing the rear to fit even more... :-o
When making a new trans tunnel, it helps to have no windshield and to be 6'3".
PostPosted: Thu Jun 12, 2008 6:52 am
Some more progress pics...
He opened up the grill for more airflow, but since the IC will be anodized black, it will look fairly stock from 5-10 meters away. ;-)
Modified the stock core support top to be removable...
Yet another custom intake manifold... I think this is his third? :P
Overall view...
Here you can see where the middle of the firewall is being moved back about 6-8cm...
He's basically building a whole new tunnel from scratch. In progress photo...
PostPosted: Thu Jun 12, 2008 6:54 am
More progress...
Took a bench seat from a Mazda truck and cut it down to fit the ute...
If you look close, you can see where it was cut and rewelded in 8 places...
Working on "tubbing" the back now...
Using 3pc BBS RS wheels, sized 15x6.5. As it fits right now, it looks like the wheels can be stretched out to 15x8.5 and still tuck in nicely. :-D
One more of the wheel...
Yes, the diff has been narrowed quite a bit... :wink:
PostPosted: Thu Jun 12, 2008 6:56 am
Update...
11.75" scalloped Wilwood rotors on AP Racing aluminum hats.
Nice used door panels sourced from South Africa...
New headlight eyebrows, also from SA...
11.5" rear rotors...
Front rotor with wheel on. Not much daylight there...
It's nice to have a lift... ;-)
Made a new crossmember. Version 2 was made to be stronger and fix some geometry problems that the version 1 had...
He made a neat screw-in boss for the engine mounts so there's no nut to install underneath.
PostPosted: Thu Jun 12, 2008 6:58 am
Updates...
Front brakes, Wilwood calipers, Wilwood rotors...
New lips on the wheels...
Front versus rear...
Rear brakes going on. 11.5" rotors and Ford calipers...
Rear view...
225/50-15 Toyo Proxes...
Custom bench seat covered and in...
Custom embroidery...
PostPosted: Thu Jun 12, 2008 7:00 am
Random photos...
PostPosted: Thu Jun 12, 2008 7:06 am
PostPosted: Thu Jun 12, 2008 7:08 am
wow :shock: I love it!
http://edz280zxblog.blogspot.com/
http://www.zazzle.com/edz280zx?rf=238417716376693023
PostPosted: Thu Jun 12, 2008 7:10 am
Custom driveshaft:
Rear arches widened 3":
PostPosted: Thu Jun 12, 2008 7:11 am
A few updates...
Black ceramic coated turbo and (yes, yet another header)header:
Black anodized Blitz intercooler:
Rear view of Blitz radiator and IC:
Front view of turbo:
PostPosted: Thu Jun 12, 2008 7:13 am
Side view of turbo:
New custom core support top piece:
Hot pipe and TIAL blow off valve:
Lower view of the ceramic coated exhaust manifold:
TIAL wastegate:
Stainless downpipe and exhaust with V-band clamp:
3.5" in and out stainless Borla muffler:
PostPosted: Thu Jun 12, 2008 7:16 am
And from today...
Steve used the front rotor and caliper from a motorcycle to make a custom e-brake, mounted on the driveshaft.
Custom e-brake:
Rear wheel view:
Rear brakes done:
The exhaust tucks up VERY close:
The center section is actually an oval pipe so it can fit closer to the floor:
Front brakes done:
New carbon fiber front spoiler:
Close-up of the spoiler:
PostPosted: Thu Jun 12, 2008 2:32 pm
Absolutely phenomenal!
PostPosted: Thu Jun 12, 2008 6:21 pm
We're hoping for around 1750-1800 pounds and about 400hp. 8)
Should be quite fun. And scary. :mrgreen:
PostPosted: Fri Jun 13, 2008 10:38 am
I tip my hat to thee! Awesome project!
http://www.youtube.com/user/myz32rocks?feature=mhum
PostPosted: Fri Jun 13, 2008 11:28 am
JNC Fanatic
:shock: :shock: :shock: :shock: :shock:
Amazing. Very, very cool. :tu:
PostPosted: Fri Jul 11, 2008 4:27 pm
Stopped by to check on progress today...
Trans-tunnel-mounted e-brake went inlast week and works very well...
Carbon Fiber spoiler on...
Air filter and IC piping mocked up and "done"...
PostPosted: Sat Jul 12, 2008 1:01 am
that has to be one of the toughest 1200 i have seen. im really liking the brake and diff side of things. really nicely engineered
1981 nissan c31 laurel
1984 datsun 910 wagon
PostPosted: Sat Jul 12, 2008 11:50 pm
That is one badass looking vehicle
1969 Datsun 510 (Project) - 1988 528e (sold) 1991 Integra "Pig" Sold :'( - 2002 RSX-S (Daily Driver)
Users browsing this forum: boostdtalon and 4 guests
