It is currently Sat May 30, 2015 5:34 am
 Post subject: Chassis Saver - protective coating
PostPosted: Mon Nov 07, 2011 9:27 pm
I've been hearing a lot of good things about this particular product. Just kind of wanted to see what people's experiences have been. Does anyone on here use this stuff?? It really looks durable and tough for all kinds of road conditions. The good: being that they claim you can apply over rusted areas (which I'm not comfortable with but some people are). They also recommend you can apply it to any and all vehicle undercarriages that you want to protect. Youtube videos also show it will not chip even when beat with a hammer.
The bad: once it is applied, it's not coming off. Sandblasting will require a few hours for small areas to remove. So basically, should therefore it should only be applied for the last and final restoration projects.
So, I'd like to see what everyone's experience is with this stuff.
http://www.youtube.com/watch?v=PG0S7KQzRvk
 Post subject: Re: Chassis Saver - protective coating
PostPosted: Fri Nov 18, 2011 10:03 am
While it looks pretty durable, what's to protect from rust coming from the other side of the metal?
PostPosted: Fri Nov 18, 2011 11:51 am
That can be said about any protectant really. All you can do is cover all surfaces as much as you can and hope you did it right lol.
Money Pits:
PostPosted: Sat Nov 19, 2011 10:39 am
I've used this product only on certain parts, like my corolla's battery tray and tie down. It works well, but I made sure to rid the rust first. It doesn't come off easy that's for sure.
1980 Toyota Corolla 2DR Sedan - 3TC Street Modded
1980 Datsun B310 Coupe - Low + Slow
2006 Scion xB - DD
PostPosted: Tue Apr 10, 2012 7:05 pm
ive used the brush on truck bed liner... works pretty good but it does chip if you scratch it up good
mx32 2jz swap in progress
