It is currently Tue May 21, 2013 11:20 am
 Post subject: 1982 SAPPORO with pics
PostPosted: Sat Mar 06, 2010 10:31 am
1982 sapporo 2.6 I4 Automatic. Here some pics
PostPosted: Sat Mar 06, 2010 4:18 pm
Looks very clean from the photos. :tu:
Did you just get it?
 Post subject: 1982 sapporo
PostPosted: Sat Mar 06, 2010 7:30 pm
Yes just got it month ago it was a dealer trade in :D
PostPosted: Sat Mar 06, 2010 8:35 pm
Yep, pretty tidy :tu:
What are your plans for it?
You might want to have a look at sigma-galant.com, there are a few of these models on there that members have done up. It's an Australian based site so they are mainly known as Scorpions, but some are Sapparos as there are international members too.
PostPosted: Sat Mar 06, 2010 10:02 pm
im thinking of restoring and getting some rims for it
PostPosted: Mon Mar 08, 2010 12:31 am
Nice car, love the Galant Lambdas!
PostPosted: Tue Mar 09, 2010 9:03 am
nice car)
very brutal 8)
PostPosted: Tue Mar 09, 2010 10:12 pm
Niiice O.G. Sapporo! have you got any mods planned?
PostPosted: Tue Mar 09, 2010 11:49 pm
I wanna drop it but have no idea where to start.and i wanna get the missing center console replace
PostPosted: Wed Mar 10, 2010 2:16 am
planning to lower it! I was hoping you would say that (cause i didn't want to say how DAMN badly it needs it!)
there's a right way and a wrong way to do just about anything... the lowering of a sapporo, as I have recently found out, is not necessarily so. if your shocks and struts ARE NOT completely blown, you may be able to modify the bump stops (cut them down) and cut down your coil springs. I was very surprised at how well my car rode with two coils cut front and rear! (the rears are progressive, with different thickness coils top to bottom, you want to cut the thicker side) this is NOT the recommended method of lowering a vehicle. it usually results in a bumpy harsh ride. (but then again, this type of drop usually results in prematurly wearing out your shocks/struts anyways!) Remember, you MUST cut down the bump stops. I also avoided opening the brake system hydraulics by cutting a notch in the bracket that holds the two soft lines together on the strut, and slipping the line out the back! (re-install the retaining clip vertically thereafter) use the proper McPherson coil-spring compressor tool to remove the front springs, and the rears drop out one at a time by removing the shock and prying the axle away from the spring at the perch.
with the two coils cut, the car should sit close to 2 inches lower, and seems to have a pretty flat ride (check my recent pics)
the RIGHT way to lower the thing, is to run a short stroke strut and shock setup, and custom made shorter/higher rate springs, or go to fully adjustable coilovers front and rear. I'm planning on making a set at some point, probably using 'Ground control" parts, and tokico illumina inserts for the MR2. (and progressive rate bump stops!)
good luck! hope my rambling is of help! :tu:
Hectors. Vintage Japanese restoration and retrofit:
www.hectorschopshop.com
PostPosted: Wed Mar 10, 2010 10:27 pm
yes thx for the tips :D
PostPosted: Fri Mar 19, 2010 2:06 pm
Hey guy got new wheels for my ride wat u think,next step is lowering it but still getting info on how to do it right :D will post more pic later
http://i1021.photobucket.com/albums/af3 ... 1269301745
http://i1021.photobucket.com/albums/af3 ... 1269301851
PostPosted: Fri Mar 19, 2010 3:13 pm
niiiice! we're on the mesh vibe! the offset difference looks like a lot...but it's probably close to correct knowing how badly they're set up stock (whoever designed the front to back track width and wheel well shape must have been thinking staggered all along!)
those wheels really unlock the potential in your car... even with the stock paint....it could be a contender... bite the bullet. build coilovers. (Or airbags!!?) kill the fender gap.
PostPosted: Mon Mar 22, 2010 4:54 pm
More pics
http://i1021.photobucket.com/albums/af3 ... 1269301924
http://i1021.photobucket.com/albums/af3 ... 1269301955
http://i1021.photobucket.com/albums/af3 ... 1269301989
http://i1021.photobucket.com/albums/af3 ... 1269302018
http://i1021.photobucket.com/albums/af3 ... 1269306401
http://i1021.photobucket.com/albums/af3 ... 1269306421
PostPosted: Mon Mar 22, 2010 8:33 pm
my car just found another brother!
PostPosted: Mon Mar 22, 2010 8:49 pm
Nice car..... now the question... Who the hell would trade that in on a new car!! And what did they possibly get that is cooler than that!
Brad D.
PostPosted: Mon Mar 22, 2010 9:43 pm
mesh is good, but find another set of rears for the front :wink:
PostPosted: Mon Mar 22, 2010 10:35 pm
Tried to get staggered look lol :) ,Lowering is next so if can someone recommend a shop pref in Los Angeles to lower my car id appriciate it thx
PostPosted: Tue Mar 23, 2010 1:17 am
Shinzo Auto is old school and a supporter of JCCS.
PostPosted: Thu May 20, 2010 7:31 pm
Got new rims 16x7 38 offset front 16x8 0 offset back
http://i1021.photobucket.com/albums/af3 ... 1274408732
http://i1021.photobucket.com/albums/af3 ... 1274408771
http://i1021.photobucket.com/albums/af3 ... 1274408832
http://i1021.photobucket.com/albums/af3 ... 1274408975
