It is currently Fri Feb 27, 2015 2:30 pm
Post a new topicPost a reply Page 5 of 9   [ 174 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Mon Jul 27, 2009 6:07 pm
i went to the swap meet in sac and picked up a dizzy while i was at the swap meet he started rebuilding the heater box
the ei dizzy i picked up
and my non smog intake painted blue to match the block
TacoDelRio wrote:
PostPosted: Fri Jul 31, 2009 12:46 am
got a weber 32/36 today
some pics of the engine compartment excuse the wiring mess im running the wires for the fan controler atm so its kinda messy but the recerver dryer is mounted
compresser mounted with idler pully
and a over all shot of the car it looks like i raised it a little but in reality the supention needs to be settled cause i picked the car up again
im working on a deal for a header locally
now a question with the weber adapter i have the throttle linkage will bind since it came off a truck the carb is already set up for a cable what is a good vehicle to pull a cable setup from? should i take everything pedal and all? im thinking of pulling it from a 620 or a 521 would this work?
PostPosted: Fri Jul 31, 2009 7:44 pm
620 would probably be the easiest, but you can pull the cable/pedal from almost any Nissan and it will work. I've used S10 200SX, S110 200SX, HL-A10, Z31 300ZX, 620, and 720...
S110 200SX is ideal but it's a loooong cable. Good for the KA swap. :wink:
620 should have the most appropriate length cable. :tu:
PostPosted: Sat Aug 01, 2009 12:32 pm
cool thread!!...lots of progress
Voodoo Racing
Lexus V8-powered AE86
PostPosted: Sat Aug 01, 2009 4:46 pm
Cars come a long long way dude.Any intention to paint it?
PostPosted: Wed Aug 05, 2009 6:30 pm
yeah i do intend to get a good paint job on it i just havent decided on a color yet and im not getting that header i posted dude is on drigs and wants $300 for it :shock:
PostPosted: Wed Aug 05, 2009 8:06 pm
If it's ceramic-coated, $300 isn't really out of line. Mind you it's no "bargain", but not terrible.
Hell the Kirk headers from Nismo were $275, and they were just chrome not ceramic. But they were 4-2-1. :wink:
PostPosted: Thu Aug 06, 2009 12:28 am
yeah but when i can get the same header brand new minus the coating for $170 shipped to my door i would rather go that way i am on a tight budget with this build
PostPosted: Fri Aug 07, 2009 1:17 am
as i said same header half the cost its on its way to me :D
PostPosted: Wed Aug 12, 2009 10:35 pm
header showed up just a matter of tying up loose ends now
PostPosted: Sun Aug 16, 2009 10:38 pm
been workin on the car some more the past couple days since i got the header it now has a non smog intake manifold on it that has been ported with a the weber and the header
before:
after:
tied up the rest of the loose ends and shot this
http://www.youtube.com/watch?v=EDWMOqntCDs
PostPosted: Thu Aug 20, 2009 11:39 pm
alright guys throttle cable is all tied up with a shinny barrel nut looks like this weekend im headed to the exhaust shop it is now parked in the street
PostPosted: Sat Aug 22, 2009 8:05 pm
well shes back and omfg it sounds awsome here ate the pics
and video i dont know how to embed here
http://www.youtube.com/watch?v=U9YbDmbNiBA
PostPosted: Sun Aug 23, 2009 9:10 am
JNC Fanatic
Very cool! Way to bounce back! :tu: 8)
PostPosted: Wed Aug 26, 2009 10:20 pm
roof is done and in primer now the only rust left is the little bit of cancer in the rear window frame :D
and just because its a bad ass shot
shows how low it is
did some more today i wired in a new choke relay and put in the inline fill cap i got from the yard and a new overflow tank :D
i know the engine compartment is dirty but thats the beauty of the bed liner its easy to clean and doesnt look very dirty even when its filthy
PostPosted: Wed Aug 26, 2009 10:40 pm
...I was really hoping you were going to fill in the sidemarkers, and use the other grille... :(
...And still hope you indeed are :)
Looks great though in any case, jealousy.
PostPosted: Wed Aug 26, 2009 10:44 pm
i plan to get my early fenders fixed and run the early grill but for now i have late model fenders and grill i can run
PostPosted: Thu Aug 27, 2009 6:57 pm
Damn I need to get my 610 back on the road... :x
PostPosted: Thu Nov 19, 2009 5:57 pm
damn ive been slacking on this thread
well i drove the car down to montery california (2.75 hour drive) and when i get there there is no coolent in it :shock: my "nos" overflow bottle couldnt take the heat so it melted and when the radiator overflowed it just dumped out onto the pavement well i babied it home stopping every half hour or so to make sure it was full then went to the junk yard and found a overflow bottle out of a 280zx that fit in the stock windsheild washer bottle mounting bracket
then after driving it with the weber header and freeflowing exhaust the timing chain started showing its age and since it has needed a head gasket for a while i went to work
in the next 2 shots you can see why i didnt do rings and bearings the
original hone marks are still there and there was no ring groove the lower end of this block is in great shape why fix it if it isnt broke?
the old parts
topped off with a polished DATSUN valve cover
i winterized the rust in the back window its only temporary till body work starts
and a cool pic i took while playing with my phone
while i was reasembling the overflow nipple broke on my mr2 inline filler so i took some marine apoxy and a bit of brakeline problem soved
whew thats my update she pulls hard now and when its wet its very difficult to keep the rear tires planted :D
PostPosted: Thu Dec 03, 2009 4:52 pm
well today i started bodywork O_O its really not that hard just time consuming as some may remember when i got the car the early 73 left fender was damaged as seen here
and you can kind of see it here
now i spent about an hour with a hammer and a few dollies and got it to this point
its not done but its almost ready for filler the way it is now a little more time with the hammer and dolly and it will be good as new
