It is currently Tue Jun 18, 2013 3:45 pm
Post a new topicPost a reply Page 5 of 6   [ 107 posts ]
 Post subject: Re: DeRuX's GC10 skyline
PostPosted: Mon May 21, 2012 7:05 pm
The part number for the sleeve I got is 214-1100. They are the threaded collars with 2 weld rings. They cost $120 for the pair.
As for what I did in the rear go back a a page or so and you will see. I used all victory 50 stuff from Japan. Woodie I would try there for some of the items you are looking for.
Ya it would be cool if we had a cross for all the hako stuff that was available from other car here in the USA.
PostPosted: Mon May 21, 2012 7:57 pm
Has anyone developed any kind of cross reference for what fits Hakos? ie: suspension components, brake pads, steering components, and so on.
i think we should develop a sticky and try to come together and compile this data!
That would be awesome as I will be Taking delivery on my 72 in June! Been trying to keep up with all the topics seeing what's what!
Jose
PostPosted: Sun May 27, 2012 10:19 pm
So I got the the car on the ground this weekend. At first I put one side together complete with wheel. Then used the jack to put it where I thought it looked best. After that with a few measurements I put the other side on and lowered that car. Once again it sat on the jack and the rocker was 3 inches off the ground. I do not have a pic of that and now wish I did. So I made a call to see where other people had there car at. I got 5 inches on the rocker from 2 people. So up the car went and made some adjustments got the car back on the ground. Here are some in garage shots and one of a completed strut.
The car sits at 4.5 inches to the bottom of the rocker flange. I tried moving the camber plates in to get more camber but they need to be modified a little to get more movement. So the whole front came back apart. I also at this height the coil over adjustment for the front is about 1 inch from the top. So I am going to order some longer springs in a 5k spring rate. After those and my bump spacer come in the car will be puts back together. Then the out side shots will come.
PostPosted: Sun May 27, 2012 10:23 pm
I dug through some photos and her is a quick not so great before and after shots.
I think it came down a little.
PostPosted: Fri Jun 01, 2012 5:19 pm
So I got my bump steer spacers done.
They are a very tight fit onto the knuckle. I have not tested them onto the struts yet. I need to cut the backing plate a little to make room. I have made four extra sets and can make another 5 sets if needed. I only got enough screws for the 10 sets. Once I make sure they fit good I will be making a sale thread.
PostPosted: Wed Jun 06, 2012 9:14 am
DeRuX wrote:
The sleeves are made by
Design products racing
5462 OCEANUS DR STE E
Huntington Beach, CA 92649-1042
Tel - (714) 892-1513
email - dpracing@dpracing.cnc.net
website: http://dpracing.co/
They are alum with steel inserts pressed into the ends for welding them to the strut.
I found there website and it is
http://dpracing.co/
They have picture on it and other items that they sell.
PostPosted: Sun Jun 24, 2012 4:43 pm
So today was a good day. got the brakes bleed this week and today took the car out for a drive. Everything worked well. Had a little smoke from oil on the exhaust but other that that no problems. This is the first time in 4 years that I have driven this car. I have to tell you it was a good time. So here is my best before and after shots of the car. From stock to dropped.
PostPosted: Sun Jun 24, 2012 9:18 pm
First time in 4 years ?...
Really?
PostPosted: Mon Jun 25, 2012 7:05 am
I could make tons of excuess about why it never got out in the past 4 years. I was starting to be that guy that you see with the car under tons of stuff in his garage. You all know that guy i am talking about. I have to admit thou that eric buying his red car and josh's videos have made me get this car back on the road. So I am very thankfull for that.
PostPosted: Mon Jun 25, 2012 9:31 am
I'm not criticizing...
I know where you're coming from... I bought a first gen 72 Honda Civic ex-SCCA race car once
Had it for about 10years, I moved it to 4 different houses over the years (we were renting and moving around a fair amount)
Rebuilt the high comp race engine 3 times, and it ran for a total of 1hour in those 10years
It was the thorn in my side ...
I sold it last summer to an ex-Navy guy in San Diego who made it a father/son project and now the little pumpkin is running again...
Time & money, right?
When you have one, you usually don't have the other...
PostPosted: Mon Jun 25, 2012 9:59 am
Pearoasted on my Facebook wall, all credit to you of course. Truer words have never been spoken. :tu:
Car looks fantastic lowered, you should be proud. Congrats on getting it running & driving again!
PostPosted: Mon Jun 25, 2012 10:03 am
Hey Camshaft
I hardly came up with that one... lol...
Not my invention...
Time & money have been mutually exclusive for a while now... hahahaha
PostPosted: Mon Jun 25, 2012 10:54 am
Hey Camshaft
Not my invention...
Right? Tell me about it! I've been selling off projects, trying to thin the herd, and it's depressing to see that I've owned a car three years and driven it a total of 1800 miles in that period... :( Keep driving and enjoying your Skyline, you've put in a lot of hard work!
PostPosted: Mon Jul 09, 2012 2:51 pm
Hey Derux
when you swopped out your rear suspension what bushes (isolators) were on the rear subframe where it mounts to the rear floor. Im rebuilding mine and cant remember what bushes were used for the body contact areas.
www.thegtrshop.com
PostPosted: Mon Jul 09, 2012 2:56 pm
I used the whiteline poly bushes and they just bolted straight to the body. I did not use the stock rubber\washer combo one.
PostPosted: Mon Jul 09, 2012 2:59 pm
do you mean the bushes that inserted into the subframe or an islolator between the subframe and body?
www.thegtrshop.com
PostPosted: Mon Jul 09, 2012 4:26 pm
I think what he means is something like this:
Where the poly bush and crushtube just butt up against the body without anything in between?
PostPosted: Mon Jul 09, 2012 9:23 pm
What Kev said.
PostPosted: Mon Jul 09, 2012 11:02 pm
DeRuX wrote:
What Kev said.
Did u use the same for the subframe, not the moustache bar>
Cheers
www.thegtrshop.com
PostPosted: Tue Jul 10, 2012 9:08 am
I used the same style bushings for my crossmember and mounted them the same as Kev's moustache bar. The only difference is the crossmember uses a cupped washer on the bottom. So when I mounted my crossmember it went
Body, top bushing, member, bottom bushing, crush tube, stock cupped washer, flat washer , spring washer and nut.
here is a shot of my bushings. You can see how one washer has a indent in it for the cone washer. (bottom bushing)
Then in this shot you can see the two large cone shaped washers I used
