It is currently Sat May 18, 2013 2:19 am
Post a new topicPost a reply Page 1 of 3   [ 50 posts ]
Go to page 1, 2, 3  Next
 Post subject: The Mazda (M13P) Luce Rotary Coupe RX87
PostPosted: Sat Mar 24, 2012 10:49 am
This thread is for the appreciation and technical specs of the 1969-71 Mazda M13P Luce Rotary Coupe (R130) RX87...Feel free to post pics, questions etc. for this rare piece of Mazda Rotary History...
rotorking
Mazda RX2 S122A S2
http://rx2re.weebly.com
 Post subject: Re: The Mazda (M13P) Luce Rotary Coupe RX87
PostPosted: Sat Mar 24, 2012 10:53 am
Make: Mazda
Model: Luce Rotary Coupe (R130)
Options: P/W, P/S & A/C
Model type: (RX87 SDX-A A/C, P/S & P/W. 1970~71)
(RX88 DX-B A/C & P/S. Oct.1969-Oct.1970)
(RX89 DX-PS only. 1970)
Body style: 2-door pillar less coupe
Seating capacity: 5
Chassis-code: M13P
Year(s)-produced: 1969-71
Total-production: 976 (1969-542/1970-431/1971-3)
Body-length: 4585 mm
Body-width: 1635 mm
Body-height: 1385 mm
Wheelbase: 2580 mm
Front-track: 1330 mm
Rear-track: 1325 mm
Ground-clearance: 185 mm
Turning-radius: 5.3 m
Curb-weight: 1255 kg (SDX-A)/1185 kg (DX-B) & (DX-PS)
Engine-code: 13A
Engine-type: twin-rotor Wankel
Engine dimensions: 565x590x555 mm
Engine weight: 146 kg
Combustion chamber volume: 655 cc x 2
Displacement: 1310 cc
Compression-ratio: 9.1:1
Compression-pressure: 9.2 kg/cm2 @ 280 rpm
Firing-order: 1-2
Induction: single 4-bbl Hitachi carburettor (2D2834X)
Ignition: twin distributor (points-type)
Max.power-output: 126 ps @ 6000 rpm
Max.torque-output: 127 lb-ft (17.5 kg-m) @ 3500 rpm
Port timing: intake opening 32deg ATDC
intake closing 45deg ABDC
exhaust opening 77deg BBDC
exhaust closing 36deg ATDC
Idle speed: 700 rpm
Points gap: 0.45 mm +/- 0.05 mm
Dwell angle: 58 deg +/- 3 deg
Leading timing: 5 deg BTDC @ 650 rpm
Trailing timing: 0 deg TDC @ 650 rpm
Plug lead type: HP5-10F
Distributor model: Leading (TVB-2ML)/Trailing (TVB-2NR)
Capacitors: 27 micro farads +/- 10%
Spark Plugs: NGK B7EE/B8EE or B9EPD
Plug Gap: 0.6 mm
Engine oil capacity: 5.0 l
Coolant capacity: 8.8 l
Thermostat type: wax (opening temp. 82 deg +/- 1.5 deg and fully open @ 95 deg)
Battery model: NS60L 45Ah
Starter model: MV1.0/12XL (1.0ps)
Alternator model: AG2060T (0.56W) 13.5-15.0 v
Drive-layout: front mounted engine (longitudinal), front-wheel-drive
Transmission: 4-speed synchronized manual
Clutch pedal height: 195 mm
Clutch free play: 0.5~30.0 mm
Suspension: independent front with upper and lower wishbones with telescopic shocks
independent rear with trailing arms with coil springs and shocks
Vehicle height from fender center line: front 404 mm +/- 10 mm
rear 339 mm +/- 10 mm
Front wheel caster trail: 1.00 mm
Front wheel side slip: 0 +/- 3.00 mm
Front wheel toe: 3 +/- 3.00 mm
Rear wheel camber offset: 7.00 mm
Rear wheel toe-in: 1.5 +/- 2.5 mm
Rear wheel camber: 1 deg 05 min +/- 30 min
Front axle shaft length: 417 mm
Front axle dia.: 31 mm
Brakes: disc/front - drum/rear (servo assisted)
Hand brake adj.: 3~10 notches
Brake master cyl. dia.: 7/8"
Front caliper piston dia.: 2-1/4"
Rear wheel cyl. dia.: 13/16"
Stopping dist.: 14.0 m from 50 km/h
Steering: rack and pinion (power assisted)
Steering gear ratio: 19.3:1
Steering wheel dia.: 400 mm
P/S fluid & capacity: ATF fluid (1.0l capacity) A40 belt
P/S pressure: 50 kg/cm2
Gear ratios: 1st-3.333:1
2nd-2.056:1
3rd-1.292:1
4th-0.964:1
Rev-3.727:1
Final-4.875:1 (39T ring gear/8T pinion)
Final drive oil: SAE90 (GL-5) 1.3l capacity
Tires: 165HR15 (1.8-2.0 kg/cm2 front - 1.4-1.6 kg/cm2 rear)
Rim size: 4Jx15WDC
Top speed: 118 mph (190 km/h)
Fuel tank capacity: 65l
Mileage: 11.5 km/l @ 60 km/h
rotorking
Mazda RX2 S122A S2
PostPosted: Sat Mar 24, 2012 11:34 am
Some pics of the Luce M13P...
rotorking
Mazda RX2 S122A S2
PostPosted: Sat Mar 24, 2012 11:59 am
Some matics of the M13P...
rotorking
Mazda RX2 S122A S2
PostPosted: Sat Mar 24, 2012 12:06 pm
The 13A...
rotorking
Mazda RX2 S122A S2
PostPosted: Sat Mar 24, 2012 8:00 pm
Nice tread RotorKing
Bless up
PostPosted: Sat Mar 24, 2012 10:31 pm
Amazing car and beautiful steering wheel :wink:
REgards, Mo Melville
PostPosted: Sun Mar 25, 2012 7:15 am
Enjoying your vids wasabicars and I always was fascinated with the M13P...keep 'em coming!!!
rotorking
Mazda RX2 S122A S2
PostPosted: Sun Mar 25, 2012 8:10 am
This is a montage and a closer look at a mint all original RX87 with spider webs and all lol...Although these cars were only RHD the firewall did have blank holes for LHD...
rotorking
Mazda RX2 S122A S2
PostPosted: Sun Mar 25, 2012 8:24 am
Here's one getting started after 24 years sleeping...enjoy and watch it in 480p for better quality...
http://youtu.be/6q2iwamj6YU
http://youtu.be/Nq6kL-RYaIY
rotorking
Mazda RX2 S122A S2
PostPosted: Sun Mar 25, 2012 8:26 am
Heh RotorKing glad to see you making posts here rather than Ausrotary.com
PostPosted: Sun Mar 25, 2012 8:28 am
Thanks bro lol how are things on your end?...
rotorking
Mazda RX2 S122A S2
PostPosted: Sun Mar 25, 2012 8:44 am
Everything Bless you know, just found out we are having our first BABY. We are also moving to Tucson Arizona in May so we are very excited you know.
PostPosted: Sun Mar 25, 2012 9:37 am
Congrats and all God's blessings bro!!
rotorking
Mazda RX2 S122A S2
PostPosted: Sun Mar 25, 2012 10:45 am
Congratulations zionfarm!
PostPosted: Sun Mar 25, 2012 11:11 am
Give Thx Cam
PostPosted: Mon Mar 26, 2012 5:01 am
I'd post photos of it but I can't be stuffed resizing them to under 800 pixels wide. I don't know why JNC reduced the max width to only 800. I can't update any of my other threads now without re-uploading every image at the reduced size! :td:
Sorry about the side track. Keep up the good work Rotorking! :wink:
Cheers,
Danny
L10A
L10B
KPDA
KRBB
KTBA
M13P
TVA
VA
PostPosted: Mon Mar 26, 2012 4:10 pm
Thanks Danny, and i know what you mean with the pic size lol it sucks but say what i just put the pics on photobucket and post them...Great find btw Danny and i look forward to more vids of it...:)
I await your vids wasabi lol you have been given a challenge to find more R130's haha...stay cool
rotorking
Mazda RX2 S122A S2
PostPosted: Mon Mar 26, 2012 4:51 pm
Freshly rebuilt 13A...
rotorking
Mazda RX2 S122A S2
PostPosted: Tue Mar 27, 2012 8:18 am
How much did they have in common with the piston-powered RWD Luce? We got the LHD Luce/1800 here in the States.
