It is currently Fri May 24, 2013 11:05 pm
Forum lockedPost a reply Page 18 of 25   [ 490 posts ]
Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 25  Next
PostPosted: Sat May 21, 2011 7:05 pm
Is there a good radiator repair shop in your area? They can usually braze it for you pretty cheap if so.
PostPosted: Sat May 21, 2011 7:08 pm
Ya there is actually. I'll give them a buzz.
PostPosted: Sun May 22, 2011 2:37 am
Kostamojen wrote:
Anyone know how to do brazing?
Aluminium? I have then:
http://www.youtube.com/watch?v=CJ42scaWFnw
I have a sort of brazing rods like that, with a little practise you can do the job too
PostPosted: Sun May 22, 2011 4:39 pm
It would cost me more to buy the required tools than to have a shop do this quick...
PostPosted: Mon May 23, 2011 12:01 am
Only the welding sticks you need, but quickest way would be let do it indeed.
PostPosted: Mon May 23, 2011 3:52 pm
I found a welding shop to do the pickup tube for $20, so I'm all set :)
Meanwhile I'm waiting for my cylinder heads to get fixed up at the engine shop, I started working on getting stuff ready...
I also rebuild the master cylinder and some other brake bits and installed them:
PostPosted: Mon May 23, 2011 6:45 pm
Gorgeous. :shock:
Some day I hope to build a car half this nice. :P
PostPosted: Tue May 24, 2011 12:52 pm
Any advise on how I should route the fuel system?
PostPosted: Tue May 24, 2011 4:57 pm
Just got back my modified pickup-tube from Lewis Welding Works (In Roseville). They did an awesome job matching up the pickup tube from the 1400 to the 1100 so I can use the 1100 pan
If anyone ever needs anything welded in the Sacramento area, this is the place to do it! They do all sorts of crazy stuff, even those half-length VW busses! Awesome old hot rod chassis in the shop getting worked on too. Good stuff.
PostPosted: Tue May 24, 2011 4:59 pm
Plenty. :mrgreen:
Can you be more specific?
PostPosted: Tue May 24, 2011 5:08 pm
Alright, here in lies my confusion with the fuel system...
The service manual doesn't show this exact car for some reason. The sedan model shows only one little evap reservoir, while the wagon shows 2 like this coupe, but it doesn't show the same routing. I have no idea what these even do anyway, so I'm curious what I should do with them.
Also the fuel tank has two tube connections for the evap/whatever. So I obviously have to run two lines to it somehow. I thought maybe use one as a return line?
Also, the white double-tube plastic thing in the fuel cap area appears to be missing parts! When I cleaned it up, all it had was a spring inside but nothing holding it down???
I did manage to route the line from the tank to the fuel pump and put a temporary break-in filter there. Everything look fine to you guys?
PostPosted: Tue May 24, 2011 5:20 pm
Yes sir.
To be perfectly honest, I prefer to do away with as much of that evap stuff as possible. :P
PostPosted: Tue May 24, 2011 6:11 pm
Do you just ditch it all and plug everything up?
PostPosted: Thu May 26, 2011 9:32 pm
Alright, more about the fuel system... I'm just not certain what to do, I don't want another engine fire thats for sure.
http://i15.photobucket.com/albums/a383/ ... ksetup.jpg
PostPosted: Fri May 27, 2011 10:53 pm
That part with the spring with missing parts may be a one way valve to only allow fuel vapour to travel in one direction.
You wouldnt want fuel vapour travelling from the fuel tank the opposite way to fuel travel. That would be my educated guess.
PostPosted: Mon May 30, 2011 12:28 pm
I basically turned it into a vent. Everyone says thats not a problem... I hope.
Anyway, my crown jewel is ready to go, just waiting on cylinder heads to come back from the shop :mrgreen:
PostPosted: Mon May 30, 2011 4:17 pm
Got some more stuff installed today...
PostPosted: Tue May 31, 2011 12:47 pm
Your build always amazes me!
PostPosted: Fri Jun 03, 2011 9:37 am
That Weber manifold is a beauty. I still can't believe how immaculate this whole build is. Klingelhofer & Co. over at Super Street would do well to feature you in a "Back In the Day" segment. I know he posts here from time to time.
PostPosted: Fri Jun 03, 2011 3:47 pm
Thanks. I'll have to look him up when I'm done :)
