It is currently Wed Jun 19, 2013 4:47 pm
 Post subject: 240z Extended Wheel Studs
PostPosted: Sun Oct 24, 2010 5:56 pm
Does anyone know any company's that make extended wheel studs for the 240z. Or maybe a factory stud from another car that will work that is longer?
Thanks
PostPosted: Sun Oct 24, 2010 6:26 pm
I just read that the 2nd gen rx-7 are longer and fit, or the nissan quest are about 9mm longer. Can anyone confirm that?
PostPosted: Sun Oct 24, 2010 7:25 pm
Nissan Quest used studs 10mm longer, yes. Used those many times. :tu:
If you want really long studs, you can get 2.5" long studs from ARP (Part number 100-7708).
PostPosted: Sun Oct 24, 2010 7:51 pm
Awesome, thanks for the conformation. Do you know by chance what year Quest? Thanks so much
PostPosted: Sun Oct 24, 2010 7:55 pm
I usually ask for studs to suit a '96 Quest. :tu:
PostPosted: Mon Oct 25, 2010 9:54 am
You need to get the Quest rear wheel studs. They have the correct knurl diameter (12.9mm) and are 45.5mm in length.
The front Quest stud will not work as they have a knurl diameter of 14.3mm.
The Nissan part number for the rear Quest stud is 43083-35F00. The aftermarket studs are much cheaper. The NAPA part number cross is 6412785 and the Dorman part number is 98363
If you're at the boneyard then look for a first gen 1993-98 Quest Van.
For more info check my reply at:
http://forums.hybridz.org/index.php?showtopic=46032
Steve Golik
1970 240Z
1974 260Z
1979 810 Hardtop
