It is currently Wed Jun 19, 2013 4:29 pm
Post a new topicPost a reply Page 1 of 10   [ 184 posts ]
Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: 1986 Daihatsu L70/L80 Mira/Handi
PostPosted: Sun Aug 01, 2010 6:31 am
Sometime early this year I came into possession of this little sucker through a mate of mine who had it sitting under his house for 6 months or so. It had previously been a customer courtesy car for a car audio place on the other side of town, so I knew there would likely be a number of things that would need fixing. The motor ran, but very poorly and the radiator needed replacing, but all in all, not a bad little car for a meagre $75AUD :)
As per the thread title, it's an Australian delivered, 1986 build L80 Handi, otherwise known as an L70 Mira to Japan and other parts of the world most likely. Unlike the Mira, however, the Handi is a 2 seater van. Australian models came equipped with the 3 cylinder 850cc ED-10 mated to a 4 or 5 speed gearbox. Similarly to the L20x and L50x models, it also features a semi-trailing independent rear suspension setup.
Moving onwards, a few pictures for those who've not seen one before.
Shortly afterwards...
First port of call was to go over the car for a closer inspection on what needed repairs. There were a few small spots of rust in the roof and around the windscreen, but nothing too extensive or hard to fix. The general consensus was that there were a lot of smaller things which needed replacing/fixing, but the majority of the car was in decent shape. Next was cleaning out the piles of litter and crap filling the interior, then removing the interior and pretty much disassembling the entire car.
The worst of the rust.
That just about covers the majority of the disassembly stage.
PostPosted: Sun Aug 01, 2010 6:55 am
Over the course of the next few months, I began searching for parts and replacing or fixing things as needed. The windscreen was taken out as it was cracked and I needed access to the surrounding sheetmetal for rust repairs. A few trips to the nearest wrecker provided a few interior pieces salvaged from an L200 Mira. Over a few days, I started to pull down the engine.
Bores are in need of a hone, but the bearings and rings appear to be in an OK condition, which surprised me.
Now, the fun part! The plans for this are to lower it considerably, fit some 13" wheels, rebuild the motor and replace the remaining items needed, paint it and replace the windscreen and drive it!
After removing the rear springs for some laughs.
The purchase of some 13x5.5" +25 to replace the 12x4" +50 standard wheels. I believe they came from an early Mazda RX, though I'm unsure.
Shiny bits from Japan!
Cleaning and repainting the engine bay.
Where I am currently. Fixing some of the rust.
That just about sums up the current state of the car, but I'm currently jobless, so awaiting employment to earn some money to start getting the engine back together along with the rest of the car.
Cheers
PostPosted: Sun Aug 01, 2010 6:58 am
I've seen a few of these around here, obviously Jap import. The later 5-door version L200S were and are still produced here as the Perodua Kancil. Very popular with people doing all sorts of modifications to them - L50x 4-cylinder 16v turbo engine with power steering is basically a bolt on job.
Good luck with the resto job :tu:
PostPosted: Sun Aug 01, 2010 7:09 am
Thanks man. I'm keen to get it up and running as soon as I can, but the lack of income is a big minus :(
I'll be keeping the stock engine initially, but I've done a bit of searching and reading around on the web so I'll be building up an 882cc, 12 valve, triple carb powerhouse later on using some available bits and pieces. It won't be as quick as a turbocharged version, but it'll sound awesome and serve as a learning curve for building motors.
PostPosted: Mon Aug 02, 2010 11:46 pm
Spent a little time today working on the rust around the windscreen. My welding skills aren't the best, but I think it should hold enough and the body filler will make it look a little better. In any case, it's miles better than the gaping hole which was there previously haha.
Also welded up the crossmember where it was cracked and a piece was missing.
I should also mention at this point that at no point was this car to be built to a show finish. I quite like the bunky kinda feel it has going, so I merely want it to a roadworthy condition so I can daily it without fear that it'll fall apart on me :)
PostPosted: Tue Aug 03, 2010 5:35 am
Looking good :tu:
So you'll be using 660cc pistons to up the capacity to 882cc? The Kancil boys use quite a few types of pistons to increase capacity and compression like Proton/Mitsu 4G13 pistons (71mm I think) or Toyota 2E pistons (72mm, I think). Or the 72mm pistons from the later 12v DOHC Perodua Kelisa (Daihatsu Coure) for low compression application. Just giving you options to consider :D
PostPosted: Tue Aug 03, 2010 7:25 am
Yeah, later on when I've got a bit of money to play with, the plan is to bore the block out to use the EF-EL pistons and use the 12 valve EF head with it. If my mental calculations are correct, this should increase the compression ratio somewhere above the 10.0:1 mark. I'll ditch the EFI setup and run triple carbs off a motorbike or something similar and probably get the cam reground to be a bit more aggressive. I've done a bit of research on these little motors already, so it should work in theory :P
That being said, unemployment is a bitch and when I finally get some income, I'll be spending that on wheels for my other (main) pride and joy.
PostPosted: Fri Aug 06, 2010 12:30 am
Just spent a little more time out the front working and cursing that I used too much hardener in the body filler so it set on me after like 3 minutes. Then cursing at the seemingly endless amount of sanding. Then cursing at blinding myself while welding again.
Cursing aside, it was fairly productive and I'm just about ready to paint around the windscreen and go find a replacement to pop back in. :) Sanded back the lips on the front guards so I can put filler over those and get them looking schmick. Started putting stuff back in the engine bay. Fixed the drivers door sagging and not closing properly. Decided that the seats looked cooler without the headrests. Sat in the engine bay and pretended I was a motor then decided to call it a day.
Pics!
All fixed!
The back side of the repairs.... :?
Looking a bit closer to where i started
Random shot showing strut brace/bonnet clearance
How she currently sits
So, things left to do:
- Finish body work (more body filler and sanding, then a fresh coat of paint)
- Install windscreen
- Rebuild motor
- Purchase gearbox
- Purchase battery
- Rebuild brake master
- Vacuum the sanding dust out of the interior
- Reinstall interior
- Get wheels machined
- Buy tyres
Oh, and I have decided on a new colour for this. Out with the ratty old red and in with a new, secret colour ;)
PostPosted: Thu Aug 12, 2010 12:20 am
Haha, the stripes weren't standard anyway, and they weren't in particularly good condition either. I much prefer the cleaner look without them anyway :P
The 882cc idea won't be put into action until a later date, as I'd like to have it up and running before anything, so just a rebuild with a new seal kit for the time being. The exhaust will probably stay running out the back, mostly because Australian regulations state that the exhaust must exit behind the rearmost windows. I will, however remove the muffler in the middle of the system. ;)
I have to admit, I was a bit dubious about the steel wheels when I originally bought them off a mate who was going to use them as spares for his L200, but once I did the initial test fit, it changed my mind pretty quickly.
I've just spent a bit of time today out working on it with sanding and preparing the body for paint. Most of the glass and exterior trim is out/off and I've done most of the fiddly sanding on the passenger side of the car. The lips on the front guards have a thin smear of body filler to fill up the imperfections. I just need to finish the work on the rear guards, fix some of the body filler in the roof and sand the whole lot back.
PostPosted: Sun Aug 15, 2010 5:25 am
A minor update. Started to paint some of the bits which have already been sanded. You may notice that I'm using pressure packs, as the idea is to have this up and running as cheap as possible. Rest assured, I am at least using decent paint :P If at some later date I decide to get the paint done properly, I'll sand it all back and get it done in two pack. For now though, Ironlak!
PostPosted: Sat Aug 21, 2010 4:06 pm
Wow i cant believe i found someone in australia as brave (and perhaps as silly - no offence) as me to even think about building up a handivan.
I'm doing the exact same thing as you mate. This is awesome news for me cause now i can bounce ideas off you, hopefully you'll do the same. :D
I'll make a thread later in the day and show you what i've done.
Bloody awesome.
Cheers,
Andy
PostPosted: Sun Aug 22, 2010 5:45 am
Thanks man. It's good to find someone to ask questions with as there's not many people interested in these. Expect slow progress from me until I find employment and stop spending money on the other pit (RA65 Celica).
Cheers
PostPosted: Sun Aug 22, 2010 9:39 am
These are so cool!
PostPosted: Tue Aug 31, 2010 10:14 pm
Would love one of these as a first car! Cant seem to find 2-Doors over here though, Great job keep working on it!
PostPosted: Sat Oct 02, 2010 10:36 pm
Hey there, do you know if the suspension is interchangable with the L70V, L200, L500?
PostPosted: Sun Oct 03, 2010 8:04 pm
Such a cool thread. The Charade was sold here in the States rather briefly and occasionally I get the urge to go find one. Your build will sustain me until the day I pull the trigger and go for it, haha.
PostPosted: Sun Oct 03, 2010 9:50 pm
By the looks of it, the suspension parts are interchangeable. L200's & L500's certainly are.
PostPosted: Tue Oct 05, 2010 4:30 pm
Hi,
Great to see another L70 being saved, nice work so far.
I also have an L70 Handivan I saved from the crushers about a year ago.
Keep us posted on your progress, enjoying the read 8)
FYI, check with your local Daihatsu dismantlers for axle hub assemblys to suit the L70. Mine had chewed out the hub centre and I swear rocking horse poo is easier to come by. Eventually tracked one down and it only cost $15.00, just wish he had a spare. If the axle nut is not to correct torque, they let go pretty quick. I am sure I have the service manual for the L70 packed away too, will look into that for you.
Regards
Dave
1961 Subaru 360
1973 Daihatsu 360X (Fellow Max)
1973 Honda Z Hardtop
1976 Honda Civic 2dr
1981 Daihatsu Charade XTE
1983 Suzuki Hatch 800cc
1984 Suzuki Hatch 800cc
1986 Daihatsu Handivan
2005 Ford Courier
PostPosted: Wed Oct 20, 2010 3:43 am
Hey ill-minded, theres a steering column surround for sale on ebay
http://cgi.ebay.com.au/DIAHATSU-MIRA-ST ... _500wt_922
PostPosted: Wed Oct 20, 2010 10:39 pm
Awesome :)
Only problem I can see is that it's in NSW, and I don't think it'd live through postage in one (well, two) piece even if the seller decided to post. There's a Daihatsu wrecker on the other side of Brisbane I might check out first if nothing pops up in some of the other nearby wreckers.
l'il fella: Nice looking L70 there. Wish mine was in as good condition to begin with. I've not been able to test yet, but I think my hubs are in decent nick, but I'd say that L200 hubs would be a suitable replacement, since they're the same PCD and the front end of the car is pretty similar mechanically.
I've already got a workshop manual for an L500 which covers all the important bits and covers both ED and EF motors. If I ever run into any trouble though, I'll be sure to PM. :)
Also, there's not a lot to update at the moment as I'm still waiting on paint. Once I get that tended to, all the glass will go back in and I'll start focusing on the motor and gearbox. That is, once I stop burning money on the other car...
