It is currently Tue Jun 30, 2015 7:03 pm
 Post subject: te72 steering
PostPosted: Sun May 02, 2010 12:56 pm
i have a steering box in my car and was thinking of converting it to an ae86 manual rack. does anyone know what i need to do to make this a functional conversion
"i had planned on buying the battle version kit 1 and 2 but then realized its not for my steering setup" those unfamiliar the battle version extends steering ability thus creating better drift angles
PostPosted: Sun May 02, 2010 1:42 pm
Easiest way would be to find an '83 in the junkyard. It shares most of the AE86 front end bits and should bolt right into your car. :tu:
PostPosted: Sun May 02, 2010 7:19 pm
83 is an ae86 right? or is that the ae71?
they seem to crush to many cars where im from so 86's are more common
PostPosted: Sun May 02, 2010 7:25 pm
AE71 is 83
PostPosted: Thu May 06, 2010 2:02 am
ok, you will need to do this. get the cross member from an ae71, steering column, and control arms as well. now, from what i was told before. you will have to cut the engine mount brackets that are on the cross member from the te72 and put them on the ae71 cross member.
i might be young, but i love old school cars.
1981 corolla wagon
1985 corolla gts
model car blogspot
http://zenkitrdcoupe.blogspot.com/
PostPosted: Thu May 06, 2010 7:12 am
ive found ae71 setup but was told that the bar that goes to the rack will interfere with the header..
can anyone comment on this?
PostPosted: Thu May 06, 2010 12:08 pm
If you use the AE71 cross member, Steering column, intermediate shaft, and rack and pinion you will have to modify the exhaust manifold of a 3tc. If it was a A series motor like a 4ac or 4ag you would have been fine.
PostPosted: Thu May 06, 2010 5:04 pm
i see well i dont want to change to an "a" engine, and im not about to hack up a brand new header :S i guess stock steering it is.
is there anyway to increase the steering radius on te72 stock setups?
PostPosted: Fri May 07, 2010 5:25 am
Ive heard that the TE72 gets the same amount of angle as a AE86 with a manual rack, I would really like to clarify this for sure. Do you have a TE72 with power steering?
PostPosted: Sun May 09, 2010 9:13 am
negative on the power steering just good ol armstrong gear box
Users browsing this forum: sweave65 and 6 guests
