It is currently Sun Mar 29, 2015 9:08 am
 Post subject: te72 steering
PostPosted: Sun May 02, 2010 12:56 pm
i have a steering box in my car and was thinking of converting it to an ae86 manual rack. does anyone know what i need to do to make this a functional conversion
"i had planned on buying the battle version kit 1 and 2 but then realized its not for my steering setup" those unfamiliar the battle version extends steering ability thus creating better drift angles
PostPosted: Sun May 02, 2010 1:42 pm
Easiest way would be to find an '83 in the junkyard. It shares most of the AE86 front end bits and should bolt right into your car. :tu:
PostPosted: Sun May 02, 2010 7:19 pm
83 is an ae86 right? or is that the ae71?
they seem to crush to many cars where im from so 86's are more common
PostPosted: Sun May 02, 2010 7:25 pm
AE71 is 83
PostPosted: Thu May 06, 2010 2:02 am
ok, you will need to do this. get the cross member from an ae71, steering column, and control arms as well. now, from what i was told before. you will have to cut the engine mount brackets that are on the cross member from the te72 and put them on the ae71 cross member.
1981 corolla wagon
1985 corolla gts
model car blogspot
PostPosted: Thu May 06, 2010 7:12 am
ive found ae71 setup but was told that the bar that goes to the rack will interfere with the header..
can anyone comment on this?
PostPosted: Thu May 06, 2010 12:08 pm
If you use the AE71 cross member, Steering column, intermediate shaft, and rack and pinion you will have to modify the exhaust manifold of a 3tc. If it was a A series motor like a 4ac or 4ag you would have been fine.
PostPosted: Thu May 06, 2010 5:04 pm
i see well i dont want to change to an "a" engine, and im not about to hack up a brand new header :S i guess stock steering it is.
is there anyway to increase the steering radius on te72 stock setups?
PostPosted: Fri May 07, 2010 5:25 am
Ive heard that the TE72 gets the same amount of angle as a AE86 with a manual rack, I would really like to clarify this for sure. Do you have a TE72 with power steering?
PostPosted: Sun May 09, 2010 9:13 am
negative on the power steering just good ol armstrong gear box
