It is currently Tue May 26, 2015 11:08 pm
 Post subject: B R?
PostPosted: Sun May 02, 2010 9:46 am
im looking to drop my 81 celica gt but i have not found aftermarket springs
so i was wondering if someone could give me some ideas
thanks.
PostPosted: Sun May 02, 2010 11:04 am
No experience with it personally, but my Corona was dropped by a previous owner. I was told they heated the springs to do it...
PostPosted: Sun May 02, 2010 4:05 pm
Pedders and Lovells both make them. Whiteline has a strut tower bar and swaybars for your car, as well.
PostPosted: Sun May 02, 2010 6:51 pm
well ive googled both brands and i cant find anything for a celica do you have a direct link?
thanks
PostPosted: Sun May 02, 2010 10:35 pm
with coilovers ath the front and spring's from a toyota yaris at the back.
Shot at 2010-02-26
Shot at 2009-05-19
and here with the same wheels as your's.
Shot at 2009-07-19
PostPosted: Sun May 02, 2010 11:09 pm
Lovells, Page 16
http://www.lovells.com.au/catalogue/2009/2009-passenger-commercial-spring-catalogue-version-02-2009-09-03.pdf
Pedders
http://www.pedders.com.au/catalogue
Toyota
Celica
1977-1981 RA40, TA40
Front Shocks
8728 8728 Comfort Gas Cartridge
9728 GSR9728 GSR Cartridge
Front Shock Mounts
5875 5875 Toyota Strut Mount
Front Spring Low
2053 2053 Sports Ryder Coil Spring
Front Bump Stop/Kit
4359 4359 Bump Stop & Boot Kit
Front Sway Bar Links & Bushes
EP755 Urethane Shock Bush
EP3320/21 Urethane SwayBar_D Bush
EP3320/23 Urethane SwayBar_D Bush
Lower Ball Joint
PBJ145 Pedders Ball Joint
Outer Tie Rod End
PTE489L Pedders Tie_Rod End
Inner Tie Rod End
PTE490R Pedders Tie_Rod End
Idler Arm &/or Bush Kit
PSX1141 Pedders Idler Arm
P5824 P5824 Idler Bush Kit(Pkt2)
EP2076 Urethane Steering Pivot_Idler
Pitman Arm
PSX5241 Pedders Pitman Arm
Radius Rod Bush
EP1307 Urethane Radius_Rod Bush
5844 5844 Pedders Rubber Bush(Pkt4)
Lower Inner Bush
5830 5830 Pedders Rubber Bush(Pkt2)
EP6087 Urethane Control_Arm Bush
Rear Shock
3356 3356 Touring Black Gas Shock
8056 8056 Comfort Gas Shock
9067 GSR9067 Gas Sports Ryder
EP148 Urethane Shock Bush
EP198 Urethane Swaybar_Link Bush
Rear Spring Low
2054 2054 Sports Ryder Coil Spring
Rear Spring Standard
7054 7054 Heavy Duty Coil Spring
Rear Airbag
NOTES Special Information
Rear Sway BarLinks & Bushes
EP280 Urethane Swaybar_Link Bush
EP4010 Urethane Swaybar_Link Bush
EP3364 Urethane Swaybar_Link Bush
EP3320/14 Urethane SwayBar_D Bush
Rear Trailing Arm Lower
5842 5842 Pedders Rubber Bush(Pkt4)
EP1018 Urethane Control_Arm Bush
Rear Trailing Arm Upper
Rear Panhard Rod / Watts Link Bushes
EP427 Urethane Panhard_Rod Bush
EP963 Urethane Panhard_Rod Bush
Users browsing this forum: Yahoo [Bot] and 3 guests
