It is currently Mon Jan 26, 2015 1:28 pm
 Post subject: Oil Catch Tank??
PostPosted: Tue Apr 20, 2010 8:31 pm
Alright i just put on my Cannon intake on my 20r, Vefore i was using a stock intake and i was running a catch can from the back nipple on the valve cover to the tank and the other hose went to where the egr diaphram or what ever on the intake. No oil leaks or nothing Well now i cant use the nipple on the intake cause there is no provisions for emissions on the Cannon which is fine but now i have oil soweing on my valve cover and the front filter soaked in oil. Now my question is
Should i hook up a catch cam from the pcv valve and put a nipple on the intake and run it like that?
Or should i just hook the 2 fittings on the valve cover to a tank
I dont think putting 2 filters is going to fix the problem
Rob Wala
85 Toyota Hilux
82 Toyota Corolla
78 Toyota Corona
71 Datsun 510
PostPosted: Sun Apr 25, 2010 10:22 pm
What will it hurt if you run it nothing. I'm goin to be running one on my 2tc and one of my 20r when I get it built. Just get rid of the pcv valve all together the catch can basically works as one.
