It is currently Sun May 19, 2013 8:55 am
 Post subject: Need rod bolt torque spec for 8RC (1970) - corona mkII
PostPosted: Tue Feb 09, 2010 10:11 pm
Trying to put my motor back together and cannot find the torque spec for the connecting rods on my 8rc and of course it is now to late to get a manual tonight and I really need to get this sucker in tonight!!!
Thanks in advance for your help!!!!
Josh
 Post subject: Re: Torque Specs
PostPosted: Fri Feb 12, 2010 11:19 pm
BeauJohnson wrote:
I have a manual for the 8r and 18r and the torque for the connecting rod nuts are 5.8 - 6.6 Mkg or 42 - 48 FT LBS. Good luck on your build.
As you have only 1 post under your name, thanks for registering to help a fellow JNCer :D
PostPosted: Sat Feb 13, 2010 12:55 pm
Thank you for responding! I couldnt wait any longer so I found the torque spec for the 20r which is 45 ft lbs so thats what I used.
I got it back into my car and running but something still isn't right. My motor is noisy as hell. It could be the tranny too but IDK. I think i might have to just replace them both. This is getting rediculous. I wish I could find the problem and just fix it. I am going to check the cam bearings and the valve adjustments next.
Any ideas?
PostPosted: Mon Feb 15, 2010 3:37 am
I really appreciate the help. I have a another post going that i will be updating.
You can find it here- http://www.japanesenostalgiccar.com/forum/viewtopic.php?t=8502
