It is currently Fri May 24, 2013 2:11 am
 Post subject: TE72 gas tank removal
PostPosted: Wed Jan 13, 2010 4:25 am
Hi im going to be doing some welding by the rear of the car..and to be better safe than sorry i want to remove the gas tank...any tips, suggestions, tutorials..any help thanks
TOYOLIFE
Old school or No school
PostPosted: Wed Jan 13, 2010 11:58 pm
I've never done one on a E70 but It should be pretty straightforward...
- Drain the fuel.
- Disconnect any fuel lines/hoses and connectors for the sending unit/gauge) first.
- Check the access panels in the floor of the trunk and underneath the car to make sure everything is disconnected.
- Before you drop it remember to take off the fuel filler cap.
- While the tank is out you might want to use Marine Clean to clean out the inside.
Good luck.
PostPosted: Fri Jan 15, 2010 3:06 pm
Thanks plenty
TOYOLIFE
