It is currently Fri May 24, 2013 9:35 pm
 Post subject: WHAT IS BEST WAY TO COMPRESS TE31-51 BUMPER SHOCKS??
PostPosted: Mon Jan 11, 2010 6:52 pm
Do you just drill a hole in the shock body?
 Post subject: Re: WHAT IS BEST WAY TO COMPRESS TE31-51 BUMPER SHOCKS??
PostPosted: Mon Jan 11, 2010 7:32 pm
You can, just don't put your face in front of it when you do. :wink:
The oil inside is supposed to be under pressure, but I doubt it is after all these years. :tu:
PostPosted: Tue Jan 12, 2010 12:55 pm
I have '77 rt105 Corona and in my bumper shocks was what looked like plastic snow :shock: Just drill a hole in the base(closest to the bumper) and then hit the stud(car)side with a socket to push in....Just make sure you rivet the shaft afterwards so the bumper cant move...
YOU WILL LOSE IMPACT CUSIONING! :twisted:
----But you prolly knew this :mrgreen:
PostPosted: Tue Jan 12, 2010 5:32 pm
OK that all sounds about what ive been hearing.So now JUST DO IT!
Maybe I'll have some snow in mine also?
PostPosted: Tue Jan 12, 2010 7:58 pm
FWIW, I compressed mine (off the car) in a vise, then tack welded them in the compressed position.
PostPosted: Wed Jan 13, 2010 7:30 pm
=OK I just did this.All tips were correct.Full compression puts you even to just past the metal filler piece.
=This is real nice on the rear as the rubber end caps fill in the depressions stamped into the rear quarters.
=Oh and I had the snow also which probably served the same fuction as an oil filled shock?? :)
PostPosted: Wed Jan 13, 2010 7:37 pm
Need before-and-after pics. Stat. 8)
PostPosted: Wed Jan 13, 2010 8:04 pm
Bumpers are going out for new chrome so no after yet. :D
