It is currently Thu May 23, 2013 6:38 am
Post a new topicPost a reply Page 2 of 2   [ 36 posts ]
Go to page Previous  1, 2
PostPosted: Wed Jan 06, 2010 3:01 pm
Doesn't the choke work? Did you jet the carb, or just install it straight out of the box and leave it that way? If properly jetted, mileage should be quite similar to stock.
PostPosted: Wed Jan 06, 2010 3:30 pm
Yes everything works, however the carb hasn't been jetted yet. I don't know how to jet it, also my mechanic says I don't have to jet it. Right now theres white smoke from the exhaust, this indicates a lean mixture, so I don't really know if jetting is required.
PostPosted: Wed Jan 06, 2010 3:51 pm
Your mechanic doesn't sound like the sharpest tool in the shed. :lol:
White smoke indicates burning coolant from a blown head gasket or a cracked head. Lean mixtures don't make smoke, rich ones make black smoke, burning oil makes a bluish-white or gray smoke.
Go take an automotive class at Los Angeles Pierce College, East Los Angeles College, or Los Angeles Trade Tech. :wink:
PostPosted: Wed Jan 06, 2010 11:44 pm
I highly doubt its a blown head gasket, theres only small puffs of white smoke only when I revv the engine, not while idling I still think that its a lean mixture but I'am not 100% sure, theres only has been white puffs of smoke since I adjusted the carb, where as before there was black smoke indicating a rich mixture. The car also doesn't overheat either, temps are normal.
PostPosted: Thu Jan 07, 2010 2:02 am
I was serious about the taking a class thing. You'd be much happier understanding how things work on your car and being able to repair them yourself rather than having to pay a "mechanic".
PostPosted: Thu Jan 07, 2010 1:02 pm
Good luck. Maybe I'll see you up there if you frequent the same roads as I.
PostPosted: Tue Jan 12, 2010 12:49 am
Thanks, my car was rubbing on the right turns, I managed to get rid of the rubbing, my front left tire was sticking out considerably and was rubbing on the right turns. It turns out the camber was horribly misaligned. My friend who owns Kindred Motorsports was able to help me adjust the camber to 0 on the front two wheels. Now the rubbing is mainly gone, except for when I turn the steering completely to the left or the right. But, for the most part the rubbing is almost gone, with the 195/60/14 tires there not much I can do at this point, but I'm satisfied. My rear two tires still have to be replaced before I push the car on the corners and the mountains.
One thing that has always bothered me was the ride height on a stock AE82 seems excessively high, especially with the 13" wheels that the car comes equipped with. Ever since lowering my AE82, I feel a noticible improvement in handling and definately looks better in my opinion.
<span><span><span><a href="http://i553.photobucket.com/albums/jj396/evolutiongts/IMAG0163-1.jpg" target="_blank"><img alt="Photobucket" border="0" height="131" width="400" src="http://i553.photobucket.com/albums/jj396/evolutiongts/IMAG0163-1.jpg"></a> </span></span></span>
PostPosted: Fri Jan 22, 2010 11:59 pm
Hey guys, I need help tuning my Weber 38. I switched out my idle jets from 45 to 40. The carb seems to be running a lot better, I also advanced the timing a bit. However, the carb floods on angles (hills), and sometimes when I accelerate from a stop, it bogs really bad and I have to go WOT to clear up the carb. Would lowering the float level help get rid of the bogging/flooding? Thanks.
Oh heres a picture of me and my friend's AE82 Sedan, we're twins lol.
PostPosted: Sat Jan 23, 2010 10:16 am
Those AE82s handle like go carts when they are lowered.. fun lil cars. My friend who lowered his and my car, had an 85 brown 4 door and I had an 86 white Nova(Sprinter) 4 door. Talk about head turners when they are done up. :)
1988 Acura Da3 Integra RS
1981 Toyota Te72 Corolla
1983 Toyota Ae72 Corolla
PostPosted: Thu Feb 25, 2010 5:43 pm
Street Cam Installed
232 in 236 ext .370 lift
DC sports front strut bar installed
With the cam acceleration and power has improve dramatically. With a lot more torque at the mid rpm range, and power until the 6k redline.
A newer honda accord tried to race me on a twisty road I lost him completely on the corners it wasn't until the end that on a straight away that he finally appeared, but he was about 2 to 3 seconds behind me. At that point it was pretty much over.
PostPosted: Thu Feb 25, 2010 6:55 pm
Well what are you waiting for? Start a thread with pics!
PostPosted: Thu Feb 25, 2010 8:16 pm
Silly Honda. :roll:
That story sounds like a FWD version of Initial D. :wink: :tu:
PostPosted: Thu Feb 25, 2010 9:07 pm
KresSlyda180 wrote:
Silly Honda. :roll:
...complete with the shocked Accord driver screaming "IIE DORIFTO??!?" after the last corner. :lol:
I had never thought of these cars as being cool before. Nice work.
PostPosted: Thu Feb 25, 2010 10:27 pm
Thanks guys, it gives me great satisfaction when newer more powerful car gets destroyed by my underpowered light weight machine. 8)
PostPosted: Fri Mar 19, 2010 10:57 pm
Rear spoiler Installed :D
 Post subject: Re: 1986 AE82 Sedan Project
PostPosted: Thu Sep 06, 2012 1:49 am
We are use AE80 also nice to here your project..this is our website http://www.corolla80.com
