It is currently Sat May 25, 2013 6:25 pm
 Post subject: Fast idle problem
PostPosted: Mon Dec 28, 2009 4:57 pm
I've noticed that the engine (18r-c) seems to be idling higher than usual, I've tried to tweak the idle screw but to no avail. I suspected an exhaust leak somewhere but the engine does sound like its recieving more fuel at idle. Does anyone have any similar experience? Any help appreciated
 Post subject: Re: Fast idle problem
PostPosted: Mon Dec 28, 2009 6:33 pm
Long wrote:
I've noticed that the engine (18r-c) seems to be idling higher than usual, I've tried to tweak the idle screw but to no avail... the engine does sound like its recieving more fuel at idle.
Sounds like choke problems to me? Are you sure the choke is opening all the way after it warms up?
PostPosted: Tue Dec 29, 2009 7:31 pm
The choke is definitely opening all the way after the engines warm.
Would the choke then be partially closed the next time it starts (cold start)?
The engine is now stuttering when I try to turn it off. It sounds like its firing really slowly or just running on a cylinder.
Apart from all this though, the car goes fine from idle
PostPosted: Mon Jan 04, 2010 1:49 am
|ENGINE COLD|
choke closed
choke fully opened by hand
choke released
upon release, the choke doesn't settle to fully close, is this normal?
I'm experience weird engine shut down. After a decent drive the engine doesn't shut off instantly, it continues to stutter for a while before turning off.
PostPosted: Mon Jan 04, 2010 9:20 am
Your engine maybe 'dieseling' son. Does it continue to run after you have turned the key off? If that is the case, it is dieseling. Check this link for some causes and cures.
http://mgaguru.com/mgtech/engine/ro101.htm
1985 MX72 soon to be...
1991 MX83 soon to be 7MGTE
PostPosted: Mon Jan 04, 2010 10:00 pm
thanks Okie, I'll have to look into these causes
it seems that the high idle may be the cause of the dieseling
 Post subject: 1972 Celica RA21
PostPosted: Mon Jan 04, 2010 11:40 pm
I have exact same problem on same engine.
PostPosted: Fri Jan 15, 2010 4:37 pm
Ok, The problem was that the fast idle cam was sticking due to grease and dirt. Took it to my carb guy to take it apart and clean it out.
Solved the dieseling problem aswell
PostPosted: Mon Jan 18, 2010 10:42 am
My Corona seems to be doing the same thing.. and mine has the 22R. After you give it a quick kickdown, it runs normal. 8)
1988 Acura Da3 Integra RS
1981 Toyota Te72 Corolla
1983 Toyota Ae72 Corolla
Users browsing this forum: 79Supra, bennyd and 2 guests
