It is currently Sat Mar 28, 2015 11:05 am
 Post subject: 76 TOYOTA COROLLA TE 51
PostPosted: Wed Nov 25, 2009 11:57 am
[mod edit] please retype this minus the "all caps" tia :)
PostPosted: Wed Nov 25, 2009 12:02 pm
how long was it sitting? try the choke on the carb, might be stuck.
check timing as well, is fuel getting to the carb? check the filter, then check your pump. disconnect the line going to the carb, crank the engine and see if any fuel comes out. if not change out the pump. if it still doesnt start it might need a carb rebuild.
i might be young, but i love old school cars.
1981 corolla wagon
1985 corolla gts
model car blogspot
http://zenkitrdcoupe.blogspot.com/
PostPosted: Wed Nov 25, 2009 12:22 pm
IT WAS SITTING FOR ABOUT 7 MONTHS. I HARDLY DRIVE IT.
PostPosted: Wed Nov 25, 2009 12:27 pm
sorry for the caps......someoen on ebay told me those cars have a thermostat choke? does that sound right?. before it started right up the iddle would be high as soon as I rubbed on the gas it would die. The butterfly didint close it stayed open. also when i tried to push down on the butterfly door I could feel it getting stucked. I would have to use pressure to close it or if I move the throttle a litttle bit it would go down. I dont know if this helps. thanks for your help
