It is currently Thu Mar 05, 2015 3:43 pm
Post a new topicPost a reply Page 2 of 2   [ 37 posts ]
PostPosted: Fri Feb 19, 2010 6:40 pm
She looks beautiful, nice find! And good on you for rescuing her. ;)
1988 Mazda RX-7
PostPosted: Fri Feb 19, 2010 7:51 pm
thanks guys, you are giving me hope :) now to find that motor!
PostPosted: Fri Feb 19, 2010 8:25 pm
Nice.
May I suggest www.Rabidchimp.com and www.celicasupra.com/ to help your project flow a bit more smoothly.
1989 Toyota Supra MA70
2JZGE + Turbonetics 60-1
PostPosted: Sat Feb 20, 2010 5:20 am
were they going to scrap THAT???!!! :shock:
Well done for rescuing a piece of vintage Toyota :tu:
Dont worry about the engine for the time being; one will show up some time or later; In the meantime tend to the bodywork.
PostPosted: Sat Feb 20, 2010 11:23 am
thank you guys, well as far as body work goes I am guessing that I will have to get someone who welds, I would love to do this all myself, but I have never welded. My extent of working on cars has only been replacing bearings, ball joints etc so this is def a project!
PostPosted: Sat Feb 20, 2010 8:13 pm
Changing a motor isn't too bad. You need to disconnect all the wires and hoses and fuel lines, unbolt the trans and motor mount and take out the radiator. If you can change a wheel bearing you can do this. You need to get yourself an engine hoist and leveler. I got mine on craigslist for $70 and a brand new leveler from Home Depot for $25. Occasionally Pep Boys will have sales on hoists and you can get them for like $150 with rebate.
5Ms and 7Ms are plentiful and cheap. This should be a fun project. Good luck!
PostPosted: Sun Feb 21, 2010 12:44 am
Where do you live, ihateu3? I see you're in Ohio. I can let you borrow mine if you're nearby.
1988 Mazda RX-7
PostPosted: Sun Feb 21, 2010 8:17 am
You said earlier you couldn't find info on JZ conversions?
JZA61's are probably the most common JZ swap this side of JZ-powered MX83's and JZZ20's down here in Australia
get yourself onto www.toymods.net and do a search for "JZA61", you should turn up heaps of info on the swap
'81 Scorpion- Daily thrasher/track project. 4G52, 4.6:1 rear end, suspension work etc.
'00 Magna- 6G74, 5spd. Sensible, reliable daily, gets along pretty well though.
'79 Suzuki GS550- 580cc overbore, rejetted carbs.
PostPosted: Sun Feb 21, 2010 12:35 pm
what is a leveler? also I found a 7mge the next town over (not sure on price yet) but will all the vacuum hoses and wires hook up the same? I have started removing the motor but stopped on the wiring wondering how the new motor will tie into the old wiring
PostPosted: Sun Feb 21, 2010 12:36 pm
thank you very much, I live in ashland its 60 miles south of clevland off of I-71 (actually I am starting school in cleveland next month) but I do think my friend has a engine hoist, if not I will prolly be getting ahold of you!
PostPosted: Sun Feb 21, 2010 3:47 pm
Okay, I'm in Mentor. PM me if you end up needing it, I have a load leveler too. :tu:
1988 Mazda RX-7
PostPosted: Sun Feb 21, 2010 10:01 pm
what is a leveler?
It helps keep the motor upright as you're hoisting it. Click the Home Depot link to see a pic.
PostPosted: Fri Mar 12, 2010 4:49 pm
ok, I guess its time for an update (to bad I can't change this threads name now that I own the car)
well tonight me and my friend who is also my roomate chris decided to go out to the garage and start removing the motor, got the hood of, radiator out and disconnected everything from the top. Should be really close to pulling the motor now, just unbolt tranny, exhaust, a/c and the motor mounts. Never changed a motor before, pretty simple so far<br><br>this is the bad side of the car, i need to source the weather stripping as you can see its missing on this side<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0078.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0079.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0080.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0082.jpg" alt="" title="" border="0"><br><br>got the hood off<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0084.jpg" alt="" title="" border="0"><br><br>This looks awesome, almost like an ae86, I will def be rocking this car without a hood alot!<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0085.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0086.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0087.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0088.jpg" alt="" title="" border="0"><br>also going to do sleepy eyes eventually<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0089.jpg" alt="" title="" border="0"><br>Chris acting like hes doing something<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0090.jpg" alt="" title="" border="0"><br>QUICK CHRIS, GRAB A WRENCH AND LOOK AT THE ENGINE!!!<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0091.jpg" alt="" title="" border="0">
</div>
PostPosted: Fri Mar 12, 2010 4:59 pm
I don't think I did to bad for my first time removing a motor, wow all the bolts came off easy, even the exhaust and AC bolts, now to find a motor and the hard part begins, I am a little overwhelmed with all the hoses and wires i disconnected!<br><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0114.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0113.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0115.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0116.jpg" alt="" title="" border="0"><br>the hole blown out the side of the block!!!<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0117.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0118.jpg" alt="" title="" border="0"><br>closer view of the hole in the block<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0110.jpg" alt="" title="" border="0">
[img]"http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0118.jpg"[/img] closer view of the hole in the [img]"http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0110.jpg"[/img]
PostPosted: Fri Mar 12, 2010 5:00 pm
I had the shop sandblast the old valve covers, u can probably see in some of the old pics just how oxidized they where, and they barely had any paint left on them. &nbsp;They cleaned up very well!<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0119.jpg" alt="" title="" border="0"><br>I decided to paint them black with the raised areas in hot red, I think they came out great!<br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0120.jpg" alt="" title="" border="0"><br> <img src="http://i214.photobucket.com/albums/cc242/ihateu1979/IMAG0121.jpg" alt="" title="" border="0">
</div>
PostPosted: Fri Mar 12, 2010 8:09 pm
The new valve covers look nice! Good work so far.
1988 Mazda RX-7
PostPosted: Sat Mar 13, 2010 1:02 am
cool save! at least im not the only one on unemployment buying project cars lol!
Users browsing this forum: Google [Bot] and 2 guests
