It is currently Wed May 22, 2013 5:43 am
Post a new topicPost a reply Page 6 of 9   [ 166 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Sun Jul 11, 2010 10:34 am
unless you want MY 4M ?!? runs absolutely wonderful.
it can be out asap if you want-you gotta gimme the rain guards though ;P
SPARKLE GARAGE
雷 - BANG !!!
PostPosted: Sun Jul 11, 2010 4:46 pm
sucks about your engine Alan...hope you find a replacement soon.
1980 Cressida MX32
Old Series Garage
PostPosted: Tue Jul 13, 2010 12:10 pm
Hahaha, thanks Toji, but I think I am gonna hold onto my rain guards for now...
Vince, I still have the emblems for you whenever you need them.
So can anyone verify whether I can swap the carbureted 4M intake manifold onto the 4ME motor to make it practically a 4M?!
Someone is selling a 4ME locally and wants $150 for it. But it is quite a drive so I want to make sure before I make the trip.
Thanks!!
PostPosted: Tue Jul 13, 2010 6:02 pm
If you have a parts store that sells parts for older Toyotas, you could try ordering an intake gasket for both and then comparing them? Cheap way to find out... :wink:
PostPosted: Tue Jul 13, 2010 10:09 pm
Good call.
According to Rock Auto:
1980 TOYOTA CRESSIDA 2.6L 2563cc L6 MFI (M) [4ME] SOHC : Engine : Intake Manifold Gasket
BECK/ARNLEY Part # 0374364
1979 TOYOTA CRESSIDA 2.6L 2563cc L6 2BBL (M) [4M] SOHC : Engine : Intake Manifold Gasket
BECK/ARNLEY Part # 0374365
They have a different part number... ARGH!!!
PostPosted: Wed Jul 14, 2010 11:55 am
Hey Toji, how much do you want for your 4M? I don't really want to do a swap yet and I don't think I will find a 4M locally in the near future. Let me know bro.
PostPosted: Wed Jul 14, 2010 12:49 pm
Damn guys, let up on the rain guards!! J/k :D it's funny how many peaple mentioned it in the thread. best of luck on the engine search. I love this car, i think i have posted pictures of it on other forums. Threads showing off bad-ass j-tin.
PostPosted: Wed Jul 14, 2010 10:15 pm
Alan, you might wanna try Kenny over on celicasupra and HR.net (sarinas_dragon) He may have one for you
Gabe
 Post subject: Re: Here's My MX32 Story...
PostPosted: Sat May 07, 2011 3:29 pm
It's been a while fellas. But the motor is in and she is up ans running again for the most part.
I took off the dash cap and plan to rewrap the dash cap and arm rest.
I have a problem my tach. Tried 2 different clusters and theres no movement on yhe tach. Any ideas what it could be?
PostPosted: Sun May 15, 2011 12:09 pm
Bump it up...
PostPosted: Thu May 19, 2011 12:44 pm
So the car is up and running again.
Dash and armrest rewraped but didn't turn out as well as I hoped.
I am deciding whether to put on fender mirrors and the position of them.
Most of them right behind the side marker:
I did another pic with the mirrors a little further back:
Third option is not to put them on at all. After staring at the pics for a while, it's beginning to look like the car looks a lot smoother without them.
Opinions?!?
 Post subject: Re:
PostPosted: Fri May 20, 2011 12:58 am
12345 wrote:
Anyone?
I dont think the dohc m series head and block interchangeable to sohc m series head and block, but from head wise of carb 4m to efi 5m is interchamgeable just depends wether u keep it carb or change over, i believe u can carb the sohc efi 5m monifolds should be the same, im sohc efi 5m if u wanna take a look some time compare and contrast im up in beacon area
PostPosted: Fri May 20, 2011 7:33 am
12345 wrote:
Opinions?!?
I am kinda partial to the fender mirror things cuz i like the way they look on an older car.
:tu:
1980 Cressida MX32
Old Series Garage
PostPosted: Fri May 20, 2011 9:31 pm
And the "Story" continues...
So I was going to drive her home for the first time since the purchase and was going to stop by my friend's house to look over his car.
I was having problem staying over 65 on the freeway so I was in the slow lane. Felt a little hesitation and was losing lots of power on steep parts of the freeway. No big, just thought I'd putt her there and look her over later.
As I pulled off the freeway, she dies. Tried to start her up again, and she started, and died again as I put her in drive. Crap...
So I barely putted her into the nearest parking lot, thank goodness it was a Schucks/O'Reily's.
Called for back up and ended up spending 3 hours in the dark to find that either the fuel line was clogged and/or the fuel pump was dead.
We ended up hooking am electronic fuel pump, attached to a gallon of fuel sitting on my lap as we crawled over to his house.
That thing drank a gallon of gas in about 1.5 miles!!!
Left the car there over night outside his house and went back today to try to blow some compressed air to unclog the fuel line. It was hot and the pressure caused the fuel line to leak gas when I got there. So somehow the line got unclogged by the heat. We then tested the mechanical fuel pump, and it worked also. WTF?!
So I dumped a bottle of HEET in the gas tank and let her idle. She seemed just fine, but was beginning to run a little hot.
Took her for a drive and she did well for the whole day except when we hit a 40 minutes section of traffic. She began to heat up a little. But the traffic started flowing again just before I was gonna put over to let her cool.
Replaced the fan clutch and wow, what a difference...
I am kinda worried if the pump will die on my again. I tried calling NAPA and they pretty much told me there don't have any replacements in the US.
Any ideas what I could do to replace the mechanical fuel pump?
Here are a few pics I took yesterday before the incident mentioned above! :oops:
 Post subject: Re:
PostPosted: Sat May 21, 2011 5:27 pm
12345 wrote:
Considering I have 15x8 -22 right now.
How impossible would it be for me to run 15x9 -15 and -25?
Question: Diamond's website lists the 15x8 Pro's maximum backspace at 5". Is this what you have? That should be around -24 or -25, correct? 3mm is probably splitting hairs, just making sure what you have, to try and guess what I need. :P
Also, what's the current tire size? I'm looking for a similar look, but think I need a 195/45-15 on a 15x8 +0 (4.5" backspace).
PostPosted: Sat May 21, 2011 5:28 pm
The car look gorgeous by the way. :tu: :mrgreen:
PostPosted: Sat May 21, 2011 6:57 pm
Looks good Alan :tu:
1980 Cressida MX32
Old Series Garage
PostPosted: Sat May 21, 2011 7:05 pm
wow alan, you're car lip is so low mayor mike mcginn can use your car during winter snow problem in seattle. :mrgreen: i like your car, let meet up in old school reunion meet.
 Post subject: Re: Re:
PostPosted: Sun May 22, 2011 11:33 am
Tire size is 195/45/15.
Wheels were put on by previous owner. He mentioned in another thread that they were 15x8 -22 all around.\
I can measure the offset for you the next time I have the wheel off if that'll help. :)
PostPosted: Sun May 22, 2011 11:37 am
Thanks Vincent.
I tried calling your and texting you. Was gonna see when you wanted to measure the lip. I have a guy locally that can custom make those for you.
I am so looking forward to seeing your car!!
Users browsing this forum: Crash1976, Google [Bot] and 9 guests
