It is currently Sun Apr 19, 2015 8:46 am
 Post subject: Dumb newbie question
PostPosted: Sun Oct 18, 2009 9:58 pm
Hi!
I am completely clueless with old Toyota gear! I'm at Datsun man,truth be known,... but please don't hold THAT against me!!
I find myself currently in need of some Toyota expertise!
Can any of you identify the beast in the attached picture?
Thanks in advance for your help!
Cheers,
Mark.
PostPosted: Sun Oct 18, 2009 9:59 pm
now that I have had my manditory first post,... I should be able to show you the image! :?
Thanks in advance,..again!!
Mark. :)
PostPosted: Sun Oct 18, 2009 10:11 pm
3K?
'69 Honda C50 Cub
'79 Honda C50 Cub
'73 Honda ST90 Mighty Dax
'70 Honda SL100 motosport
'75 Honda CF50 Chaly
'86 Honda Z50R
'85 RX7 FC3S
PostPosted: Mon Oct 19, 2009 5:23 am
JNC Fanatic
Yeap, one of the K series engines. Fairly early Corolla in our part of the world.
I'm assuming it's in a Suzuki Sierra or something similar as there's a steering damper in that there picture!
PostPosted: Mon Oct 19, 2009 3:24 pm
WOW... nice spot!!! :D
It is in an old Suzuki Sierra farm ute. Just wanted to get a new dizzy cap (and leads)... oh and she needs a water pump too.
Runs rich too... so there's something to fiddle with!!!
But,..all in all, it's a really good old girl!!
PostPosted: Thu Oct 22, 2009 5:11 pm
Hmm I was going to guess Corona myself :)
PostPosted: Fri Oct 23, 2009 8:28 pm
JNC Fanatic
The dizzy's did change over the years, but basically there was the Bosch type and NipponDenso type.
Your series of K engine should be with the normal engine number. Just look forward of the dizzy and it should be there. That will make the cap a bit easier to get right.
Most nippondenso(look for a ND with numbers on your dizzy) are listed with a GD366 dizzy cap, earlier K were GD516.
Most common Bosch type is a GB708. All of these numbers are Bosch part numbers which are common at most of your local parts shops.
Again there's a couple of pumps but usually it was the change of series ie K - 3K -4K
3K aftermarket water pump usually crosses to a QCP1013
4K aftermarket water pump usually crosses to a QCP2135
These are QH part numbers but parts shops can cross reference them.
Users browsing this forum: Yahoo [Bot] and 2 guests
