It is currently Mon May 20, 2013 5:31 am
 Post subject: Air suspension on a MX32?
PostPosted: Sun Oct 18, 2009 7:43 pm
So I thought I jumped on a deal to buy a kit off a local from craigslist.
After doing more research (after I impulsed buy), I realized that what I had bought was Chassis Tech. (aka AIM/airbagitdotcom)
So with more research, I realized that they are labeled as the "dollar store" or "walmart" brand of air suspensions.
All in all i bought the kit with the following:
He is selling the following:
1 dc 5000 compressor
1 3 gallon 5 port tank
1 4 port manifold
2 2600 air bags 3/8 port
4 t-fittings
4 90 degree fittings
4 straight fittings
1 check valve
1 steel braided hose
all of the wiring for the system
dual gauges- 4 bottom
relay
These are the things he Claims I need:
1/4 inch air lines
2 2600 bags
3/8 inch air line
He sold the stuff above for $400 and claims that he bought them for 699 from chassis tech.
It only comes with 2 bags as he sold the other two. (After what I read I am not too thrilled about using their bags) What company would you guys suggest?
There are no brackets which means I need to buy some or make some.
What else do you think I need?
Was told that I will need the strut type bags in the front. But which type?
All recommandations appreciated!
Thanks for reading!!!
cron
