It is currently Tue Jun 18, 2013 8:20 pm
 Post subject: 5M-GE 2.8GT
PostPosted: Sun Oct 11, 2009 9:43 am
Hi,
Anyone familiar wz this 5M-GE ?
1) Does this engine require more than 4 litres of engine oil ?
I ask this bcuz my foreman just put a 4 litre and check the dipstick and he said ok. He's yooung chap wz a little experience plus never saw or mingle wz a 5M-GE before, i think the engine is older than him....hehe
2) Does this auto transmission require only 2 litres of ATF fluid for a
normal service ?
How much does it need for a full flush ?
Rgds
PostPosted: Sun Oct 11, 2009 7:52 pm
I think oil is 5qt if you change the filter
5qt of ATF for a flush too.
PostPosted: Sun Oct 11, 2009 10:51 pm
opsss....
conversion from quart to litre.
5 Quart = 4.73176473 Litre (L)
i hv to topup another 0.73 litre then....
thks mate
PostPosted: Sun Oct 11, 2009 11:02 pm
I should add that the ATF flush assumes you are going to lose some in the flushing process.
PostPosted: Mon Nov 30, 2009 9:02 pm
Oil and filter per the owners manual 85/86 Celica Supra
5.4 qts/5.1 liters
Auto trans drain & refill
2.5 qts/ 2.4 liters
Regards,
Arch
'86 Supra MA67
Brullen 2.5" Exhaust, HKS Fly w/7MGE clutch,ST Springs, RC Intake & TB, 2.8GT & XX emblems, Factory Add on Rear Shoulder belts, Pioneer DEH-P2000 AM/FM/CD w/CDS-P5000 CD Player, Compomotive CXNs 8x16
PostPosted: Mon Nov 30, 2009 9:05 pm
NOTE : Auto trans fluid early Supras use Type F, late Supras use Dexron II
What year Supra???
Regards,
Arch
'86 Supra MA67
PostPosted: Tue Dec 01, 2009 6:31 am
You can use Type-F fluid in a Dexron/Mercon app...it will just make it shift a bit firmer, because it does not have the friction modifier package of D/M.
These so called "racing" ATF's are just Type F with a custom dye added.
Users browsing this forum: Google [Bot], Unek55 and 5 guests
