It is currently Sat Apr 18, 2015 8:11 am
Post a new topicPost a reply Page 2 of 4   [ 74 posts ]
PostPosted: Tue Jan 04, 2011 1:46 am
Besides wrapping a cheap header like OBX will shorten it's lifespan considerably.
PostPosted: Tue Jan 04, 2011 7:09 pm
They might be inexpensive but I wouldn't call them cheap and actually the header looks pretty well put together.
PostPosted: Wed Jan 05, 2011 1:00 pm
just added more HP today... ;-)
picked up a set of these filters for my Carbs
PostPosted: Wed Jan 05, 2011 1:20 pm
Badass duder I wish I had sidedrafts for my car. Oh well soon enough I will have cbr1000 bike carbs on mine hahahaha
77 TE51
PostPosted: Mon Jan 17, 2011 7:26 pm
A few new pictures of the Header and Carb Filters
PostPosted: Sat Feb 12, 2011 4:44 pm
now I have a problem with the Celica... :(
I was driving on the freeway in 5th gear and I start to hear this werring sound and losing speed. I try to down shift to 4th, 3rd, 2nd and 1st and nothing so I coast to a stop. Try 1st again and no go. Turn the car off and back on still no first. Tested all the gears by shifting to each gear and letting the clutch out, the only one I could get to work was 4th. Luckily I was able to get the car home with 4th gear.
Also I should add that the shifter is missing some of the bushing, I think it only have the plastic cup on the end of the shifter. It had been find recently except for on occasion when it would pop out of 1st when I was first take off from a stop.
Anyone have any thoughts on the possible problem and solution?
PostPosted: Sat Feb 12, 2011 4:51 pm
In most manual transmissions, 4th gear is 1:1 so it's basically a direct drive. Which means most likely something internal has gone terribly wrong. Broken shift fork maybe?
PostPosted: Sun Feb 13, 2011 7:25 pm
no luck today... looks like the tranny is done... so now im looking for a W58
PostPosted: Thu Mar 10, 2011 6:46 pm
I picked up a W58 the other day and hope to get it installed this weekend
PostPosted: Sun Mar 13, 2011 6:59 pm
about half way there... but ran into a problem... look what someone did to the fill plug... :(
http://www.93alltrac.com/other/81%20Celica%20Hatch/W58_FillPlug_sm.jpg
PostPosted: Mon Mar 14, 2011 6:33 pm
Look conpletely fine to me
77 TE51
PostPosted: Mon Mar 14, 2011 6:34 pm
some more progress today... got the BillyM Shift Bushing mod done, can't want to test it out!
PostPosted: Sat Mar 26, 2011 5:58 pm
well... still having issues...
This is the problem with the W58 not fitting.
Here is a great ref for how to disassemble the W58: http://www.cygnusx1.net/Supra/Library/T ... x?S=MT&P=7
The W58 is on the left. See the difference with the shift lever?
So I thought maybe I could move the lever to the W58 but after removing the bolts to separate the extension housing I can only get it the far apart.
PostPosted: Sat Mar 26, 2011 6:22 pm
Check the MkI upgrade thread on celicasupra.com
Damon (turboMkI) has swapped a W58 into a MkI Supra.
IIRC, he used one from a MkIII Supra. The shifter location on the MkII is different than the MkIII. He said the MkIII location was really close to the stock W50 location on the MkI.
Not sure if the same would apply to an RA chassis, but it's worth checking out.
What's your dimension from the front of the bellhousing to the shifter?
A quick search on cs.com found this thread:
http://www.celicasupra.com/forums/showthread.php?4838-W5x-shifter-locations-in-what-Vehicles
It lists shifter locations for a bunch of different W58 configurations. HTH
A bunch of Supras :)
79 MkI - owned since 82
83 MkII
85 MkII - 1JZ
86 MkII - 6M
PostPosted: Tue Mar 29, 2011 7:40 pm
I decided F it and just cut the floor so the tranny would fit... Got it installed and running... It will have to wait til tomorrow for a test drive
PostPosted: Wed Mar 30, 2011 5:48 pm
took the car out for a spin.... everything seems ok so far.
PostPosted: Sun Apr 10, 2011 5:58 pm
Some new pictures...
Full Res version
Full Res version
Full Res version
 Post subject: Re: 93cc (Don) 81 Celica GT LB
PostPosted: Mon May 09, 2011 9:19 pm
looking to replace/upgrade my brakes pad and rotors. What do you all recommend?
Me: Image JTIN Classics: Image
PostPosted: Tue May 10, 2011 5:15 pm
Prolly ae86 stuff will work. Or go all out and see if you can get mk3 supra stuff to work.
77 TE51
PostPosted: Tue May 10, 2011 7:53 pm
I don't want to swap parts right now... so looking for parts that are for the 2nd gen
cron
