It is currently Fri Feb 27, 2015 8:37 am
Post a new topicPost a reply Page 7 of 9   [ 180 posts ]
Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
PostPosted: Mon May 24, 2010 8:52 pm
Just thought I'd update this tread. Sofar, I was ablr to source a twinsideraft manifold for my 20r. For now the 18rg transplant is on hold till I get a new head(found a crack in it :evil: Ihave a 40 mikuni and bored it out to 36 venturi and took out the front sleeve. Stock double valve springs. Also will be getting some headers too by nextweek.
test mock up:
erson cams:stg3
PostPosted: Mon May 24, 2010 11:51 pm
sick! Sidedrafts rock my socks!
PostPosted: Tue May 25, 2010 1:55 pm
Jealous!! Those are on my wish list for sure, good find!
PostPosted: Tue May 25, 2010 8:36 pm
Yes! got the siderafts up and running this morning and by lunch was done with the linkage and by 3pm was off for a test drive. Man, the sound of those twins breathing was awsome. Was grinning ear to ear :D
Anyway, was not able to put my erson cams and instead settled for the mild cam that I have till i get the right performance springs. Still, the difference in power was evident right away from the stock carbs. A bit more tuning and i think she will be good for now.
tomorrow , I will try to make a small vid of the car running. :D
PostPosted: Wed May 26, 2010 1:35 pm
Took a small vid clip of the car running. Still needs some tweaking as the carbs kinds of spits a bit. Looks like a bigger air jet is needed also need to re-adjust the rockers again. So here she is.
http://www.youtube.com/watch?v=HOIAYBS4WOw
http://www.youtube.com/watch?v=tNitXu0pSGg
PostPosted: Wed May 26, 2010 2:45 pm
Carbs are nice
on a side note how did the pedals look after mounted and which model did u use I assume u are still using the oe long pedal thats bolted to the floor
Rob Wala
85 Toyota Hilux
82 Toyota Corolla
78 Toyota Corona
71 Datsun 510
PostPosted: Wed May 26, 2010 3:17 pm
I'm not using the oem pedals anymore and have repalced it with a sparco bolt-on pedals and welded the gas pedal in place.
Here's a pic of d set-up. I have to use a camry clutch pedal and had to modify to fit my car.
PostPosted: Thu May 27, 2010 7:07 pm
but is that the oe gas pedal with the sparco welded on?
Rob Wala
85 Toyota Hilux
82 Toyota Corolla
78 Toyota Corona
71 Datsun 510
PostPosted: Thu May 27, 2010 8:09 pm
Yeah it's the oe pedal then I welded on the back plate that came with the sparco then bolted the top pedal to the plate. Your car is looking good,btw.
PostPosted: Mon May 31, 2010 12:06 pm
3tcRob wrote:
Carbs are nice
I used a 1990's toyota camry clutch pedal which had to modify to suit. The camry had d same "bend" like the early toyota trucks had. You could probably use the early 80's truck for the conversion. Unfortunately there was no truck at the j/y here.
PostPosted: Tue Jun 01, 2010 7:52 pm
ok, like the saying goes, use what you have at the moment. So id ecided to to install back my USDM bumpers. Before doing so, I decided I would like it ot be tucked in further. I had to drill out the gas charged 5mph bumper shocks. I also had to cut the end tip about 2" to make the bumper flush as much as possible. Not done yet as I still have to do some welding to hold the bracket that hold the bumper n place. Here she is for now. tomorrow I will do the front bumpers.
In this picture, the bumper is still hanging and not bolted on. Once It's done it will have about an inch clearance from the body.
PostPosted: Wed Jun 02, 2010 11:42 am
done with the front. just need to straighten it up a bit.
PostPosted: Wed Jun 02, 2010 4:05 pm
Definitely a big improvement! :tu: :mrgreen:
PostPosted: Wed Jun 02, 2010 7:17 pm
Have you been able to source any 1 piece bumpers?
PostPosted: Wed Jun 02, 2010 9:00 pm
not yet. No funds for it at the moment. just using what is at hand and making it fit better :D . maybe later when I get extra mulah to burn.
PostPosted: Mon Jun 14, 2010 7:48 am
Made my own air filter. Screen used came from a door screen. Have to put 5 layers in criss-cross pattern and then a stocking over it. i know it will be a fire hazard. I will get the K&N filter cover boot to replace it.
PostPosted: Mon Jul 12, 2010 7:44 pm
decided to keep the car. Just a new update. 7 1/4" Hella fogs. Not wired yet. all I need now area pair of 9" hella's!.
new sabelt harness.
PostPosted: Wed Jul 14, 2010 8:54 pm
Lookin good!
PostPosted: Sat Jul 17, 2010 8:03 pm
your car is very cool!!...
congratulations friend...
add in your msn my e mail, i have rt104 in PERU...
PostPosted: Sat Aug 07, 2010 5:13 pm
Thanks guys! :D Now for a new update: I just got my new Hedmann Headers I got from ebay! This one doesn't have the oxygen sensor attached to it. Can't wait to install it!
It registration time so I need to pass the snff test. So far I failed twice!! I'l get that right mixture. Here's the new headers:
Users browsing this forum: Yahoo [Bot] and 3 guests
