It is currently Wed Mar 04, 2015 1:54 am
Post a new topicPost a reply Page 10 of 10   [ 194 posts ]
Go to page Previous  1 ... 6, 7, 8, 9, 10
 Post subject: Re: 1974 Toyota Corona MarkII
PostPosted: Tue Jan 10, 2012 11:52 pm
saw this & thought of your car ...
-Matt
PostPosted: Wed Jan 11, 2012 11:21 am
That looks wonderfully good :tu:
And I like the color too
Thank you
PostPosted: Thu Jan 12, 2012 2:06 am
This car is remarkably beautiful.
Well done!
The ones here in South Africa are all rust buckets... lol
The ONLY constant, is CHANGE...
Spreading an idea through radiant osmosis....
PostPosted: Thu Jan 12, 2012 12:15 pm
Well done!
Thank you very much
PostPosted: Thu Jan 12, 2012 1:21 pm
Who supra model have you used springs and shochs from?
PostPosted: Fri Jan 13, 2012 10:38 pm
1980 Toyota Supra :tu:
PostPosted: Sun Feb 24, 2013 9:16 am
Hello, you have a very nice car.
I restore only a four-door, I have a few questions.
You change the front suspension or left home, the car behaves with another motor, as far as I understand rear disc brakes do as it did.
Thanks in advance
PostPosted: Mon Feb 25, 2013 1:37 pm
Thanks in advance
Hi,
Front and rear suspension have been modified along with disk brakes.
Thank you
PostPosted: Sun Mar 17, 2013 8:41 pm
Did you have any trouble getting the oil pan to clear the cross member?
I dropped a 7M into my '73 MarkII, and needed to swap the oil pans.
Thinking about a 1JZ in the future.
The crossmember in my car looks like this:
kolxoz
PostPosted: Sat Mar 23, 2013 6:06 pm
Just goin through this thread and not sure what happened but page 6 got interesting and is NSFW
PostPosted: Sun Mar 24, 2013 11:27 pm
i bet what happened is tinypic re-used that exact url
and it happened to be nsfw
-Matt
 Post subject: Re:
PostPosted: Mon Mar 25, 2013 12:30 am
Oracles wrote:
I really appreciate all the comments by my fellow JNC's. You guys are awesome :tu:
So last week I was cruising on freeway and felt like hood is going to fly open and had to back off pushing the car further , I then went to work on doing something about it and came up with custom hood pins to secure the hood from flying open. What do you guys think????
This looks really good. I had a similar issue with my TE27. Question, do your hood pins show through the top of the hood? I always wanted something a little more secure than the latch alone and this design appears to be it but I also don't care for the look of the hood pins showing outside the car.
 Post subject: Re: Re:
PostPosted: Mon Mar 25, 2013 10:59 am
Thanks Nic,
Hood pins are functional but I simply dont care how they look.
The whole idea behind this setup was to secure the hood little better without hood-pins showing.
So no drilling holes on top skin of the hood instead I secured them on to "secured" subframe as you can see in the pictures :tu:
PostPosted: Mon Mar 25, 2013 11:01 am
oil pan was swapped from JDM to USDM 2jz.
