It is currently Wed May 22, 2013 12:13 am
 Post subject: still 3t issue
PostPosted: Tue Aug 25, 2009 12:32 pm
Alright well heres the deal.
My car either misfires or doesnt fire at all. it tends to swich in between whenever it likes. I have my assumption what are yours?
PostPosted: Tue Aug 25, 2009 10:52 pm
distributor 180 out?
TacoDelRio wrote:
PostPosted: Wed Aug 26, 2009 12:57 am
i doubt it... its been 180* out before and it wont even start like that
PostPosted: Wed Aug 26, 2009 3:09 pm
took 3 months but shes a beast. thanks guys
PostPosted: Wed Aug 26, 2009 3:11 pm
I assume you checked all the basic stuff like plugs/wires, compression, etc?
Does it run lean?
PostPosted: Wed Aug 26, 2009 7:52 pm
i replaced all that. The pos weber didnt have a return line cand the float bowl was full so it over flowed making the car uber rich shooting out black smoke and yup, fouling plugs. so it was a carb issue causing all of this. stock carb, new plugs, and lots of seafoam fixed it.
PostPosted: Thu Aug 27, 2009 9:07 pm
I'm pretty sure a weber carb is not supposed to have a return line. The float and float needle regulate the float level. If the carb is overflowing either the float needle is just stuck (happens if the carb is gummed up or corroded inside) or your fuel pressure is way too high (should be 3-5 psi).
1970 KE17 Sprinter, 3T/5spd, TE27/AE86 underpinnings
