It is currently Wed Jun 19, 2013 3:54 am
 Post subject: Corona MkII from down under
PostPosted: Fri Apr 20, 2007 12:00 pm
My track car is a 1976 Corona Mk2 MX23
Engine:
* 2JZGE (unopened)
* 48mm individual throttle bodies
* mandrel bend extractors
* Motec M800
* 2.5" exhaust
* 148 rwkW @ 6600 rpm
Clutch and gearbox:
* 4 puck 236mm ceramic clutch
* 2100 lb pressure plate
* W58 gearbox
Differential:
* Hilux RN41 G series LSD - 3.9:1
Brakes:
* Front - 330 x 28mm rotors
- AP Racing CP5200 4 spot calipers
* Rear - 307 x 18mm rotors
- Celica ST205 2 spot calipers
Wheels and tyres:
* 16 x 7" ROH mags of some description (+36 offset)
* Yokohama Advan A032 205 50 16
Quarter mile: 13.8 @ 100mph
Humble beginnings - as purchased from deceased estate
Now:
At the track.
Hope you enjoy!
 Post subject: Re: Corona MkII from down under
PostPosted: Fri Apr 20, 2007 10:40 pm
That engine is just ***GASP!!!*** :shock:
What's going on for suspension? How did you make it trackworthy??? (holy negative camber, too!!!)
Awesome ride. Keep the stock color--looks great.
PM me if you need your classic detailed in RI/Southern MA
PostPosted: Sat Apr 21, 2007 6:04 am
Wow!
PostPosted: Tue Apr 24, 2007 5:03 am
Thanks. :)
I'm using 1000 lb/in springs at the front with a 30mm sway bar and 300 lb/in springs at the rear with a 22mm sway bar. I have Koni red (one way adjustable) shock absorbers in there. As for the camber, I modified the upper control arms to accept mre shimming. At the moment I can get 4.75 degrees of negative camber and 4 degrees of caster.
PostPosted: Tue Apr 24, 2007 8:35 am
:shock:
The whole setup sounds pretty sick. Nice.
PostPosted: Fri Jan 22, 2010 10:06 am
@gianttomato
Buddy are you still around? just read the specs of your car, seems marvelous!! but unfortunately the link to the pics are dead... can you please post new links/pics...
regards...
'73 Corona MarkII...
Users browsing this forum: 5KV14 and 4 guests
