It is currently Fri Mar 27, 2015 6:23 am
 Post subject: 2TC cap and rotor fit 2TG cap and rotor??
PostPosted: Fri Jun 13, 2014 12:51 pm
Its been a while since I tuned up my 2TG and don't remember about the dizzy cap.
Will 2TC/3TC cap and rotor fit 2TG dizzy??
My 2tg dizzy has the 2 push on metal side clips that holds the cap on the dizzy.
 Post subject: Re: 2TC cap and rotor fit 2TG cap and rotor??
PostPosted: Sat Jun 14, 2014 10:30 am
3tc cap and rotors are different, wont fit. It depends if your dizzy was originally points or electronic. Point type caps are a little smaller and will fit electronic type but will be a little loose. Electronic type wont fit points type. All 2tc rotors are the same.
So yes 2tc will fit 2tg but there are 2 different cap sizes.
p
PostPosted: Sun Jun 15, 2014 11:16 am
OK thanks for the info. :tu:
The one I have on now that I want to replace is a little loose.
So I will get a early clip on points 2TC cap :tu: .
PostPosted: Sun Jun 15, 2014 10:26 pm
If there is a gap between the cap and the "anchor" for the clip then you will probably need the later 78/79 electronic 2tc cap.
PostPosted: Mon Jun 16, 2014 4:26 pm
OK well ordered an early one already so will have to try that first.
Users browsing this forum: Google [Bot] and 3 guests
