It is currently Thu Mar 05, 2015 5:09 pm
 Post subject: T50 Transmission Question/Help
PostPosted: Fri Jun 06, 2014 7:21 am
Did a search - didn't see any results.
Does anyone know if the newer 86+ C50 transmission rebuild kits will work, at least in part, on the pre 85 T50 transmissions? I am trying to piece together a rebuild kit and I have some bearings so far but curious if I could use the synchros and other items from another kit to make it complete. Same with the W5x series trans.
Any help appreciated!
 Post subject: Re: T50 Transmission Question/Help
PostPosted: Fri Jun 06, 2014 10:13 pm
belive they share syncros With some w boxes . Doubt C50 parts will be any good.
Find partnumber of your rings on toyodiy and use the crossreferece function
Then youll know for sure wich ones fit
PostPosted: Sat Jun 07, 2014 9:43 am
thanks for the tip on toyodiy. I will give that a shot. Part numbers can be somewhat elusive though as sometimes they change part numbers or different companies use different part numbers making it hard to cross reference. But worth a shot!
in the meantime, if anyone else has any direct experience let me know. thanks!
PostPosted: Wed Jun 11, 2014 12:37 pm
The newer T50's have a stronger incoming axle bearing. Dont know if the size share same dimensions of the older bearings.
