It is currently Fri Mar 06, 2015 5:51 am
 Post subject: Tore's RS50--->MS50 4M engine Swap +ms85 diff/driveshaft
PostPosted: Thu Jun 05, 2014 4:03 am
hey! im currently in the process of taking a 5R out of a rs50 and putting a 4m in!
here si a pic like the day after we bought it.. ( last year)
4M-tailshaft,diff donor car
both engines out and on the floor
diff comming out
no rust at all
such clean
going out
both out
got the handbrake loose
new diff in
put the tires on and found out i needed to shorten a stag to get it in the right place... the mount for this stag is 2,5 cm to the left
perfect
got the tailshaft mount in ( i only need to drill 4 holes) and the tailsaft in, engine in, need new engine and gearbox mounts then its just electrical and small issues.. :)
 Post subject: Re: RS50 to MS50, 4M/tailshaft/diff from MS85 project
PostPosted: Fri Jun 06, 2014 1:58 pm
motormounts done
dad bought us som stuff.. new exhaust, brake fluid, cooling, filter, brake shoes, wiring, motor oil.. etc..
painted engine mounts and some more and stuck engine back in
moved the coil and fuel pump to teh left side, and mved the wiper fluid container to the right, going to move the battery case to the left aswell..
freaking everything is on the other side...! extended the dynamo cables and the coil, got a bit more to do.. :)
PostPosted: Wed Jun 11, 2014 8:56 am
first startup!
https://www.youtube.com/watch?v=i4-AyXZJK5M
cleaned the carb
botled the fuel pump and coil onto the fender, the wiring looks messy but i had to toss it over there because i was going to make the battery tray..
after some discussion with my dad we decided to use the MS85 radiator, so he want on and made it fit..
original vs ms85 radiator.. looks good!
i tink i need to stiffen this bar somewhat..
PostPosted: Wed Jun 18, 2014 7:29 am
when i got home from a school trip yesterday i found out that dad had done a lot, he had fixed the throttle, changed brake shoes, fixed the clutch , gearboxmounts, cooling etc.. so then we put some lights on it and had a test ride :) need to adjust the ignition its backfiring a lot!
soo.. i started working to get the grill on the car, to do that i had to modify the hood opner, since the radiator sits 5cm ish more to the front we had to turn the hod opner arround... but then the grill would not fit and the wire had to go on the other side.. so i made a lever instead..
going to stick it out through the grill
needs to do something with it to be less pointy and sharp..
oil cooler mounts
looks good
painted all the bare metal and mounted the whole grill.. but the badge is missing, it needs something there its so empty...
PostPosted: Wed Jun 18, 2014 1:53 pm
Looks great. I am thinking of doing a swap of either diff or gearbox so that I get a better ration for when driving on highway. What options are there for a MS55 2300S from 1970?
Rgds
PostPosted: Fri Jun 27, 2014 10:59 am
an MS55 i'm not shure about, but in this case the talshaft from the rs50 did not fit the 4m and teh tailshaft of the 4m did not fit the diff, so i had to swap the entire driveline...
decided to polish teh wheels, before pic
i NEED to get a badge in the grill, it looks so empty
new brake pumps for the rear..
PostPosted: Tue Jul 01, 2014 5:11 pm
The car looks great! I like the polish on the wheels
kolxoz
PostPosted: Thu Jul 03, 2014 12:56 pm
changed the brake pumps in the rear the other day , and changed the exhaust gasket, runs good and sounds awesome :D
also bought myself a Corolla for 3/4 of the price of a new front wind screen, and i needed a new windscreen for mine, turns out to be pretty rust free so ill save it for a future porject :) previusly had 230 ish HP in it so its build for 200hp ish :) converted to hydraulic clutch aswell :D
some pics with my brothers RS56
PostPosted: Sat Oct 04, 2014 11:13 am
valve adjustment
deluxe grill mounted
cleaned, adn sanded, 2 of the thingis polished
looks heaps better
interior looking as awesome as always
when over the tires with a white marker
 Post subject: Re: Tore's RS50--->MS50 4M engine Swap +ms85 diff/driveshaf
PostPosted: Wed Oct 08, 2014 12:24 pm
tried making my own site.. dunno how it worked out... :roll:
http://garage-tore.weebly.com/
PostPosted: Sun Oct 12, 2014 4:04 am
I would have recommended to jump straight to a 5M from a newer Crown (MS132) but nice work on the car none the less. :tu:
1984 Toyota Crown: 6M-GE swap in progress
1988 Toyota Hilux: getting worked back to life
cron
