It is currently Thu Jan 29, 2015 5:36 pm
Post a new topicPost a reply Page 2 of 2   [ 33 posts ]
 Post subject: Re: Toyota Mark II twin Turbo
PostPosted: Tue Apr 29, 2014 8:21 am
Your car's ECU is a neural net processor, a learning computah.
PostPosted: Tue Apr 29, 2014 11:33 am
Cool MarkII, axle code says G series, sweet...
Have you checked the distributor timing and TPS adjustment?
Where are you in TX?
1977 Celica coupe
1977 280z - wife's car
1989 Cressida
PostPosted: Tue Apr 29, 2014 8:33 pm
Thanks JZCelica,
timing checked and adjusted....response got better.
TPS inspected anf found to be the the factory set pesition but voltage output not verified.
I really believe the MAF needs some attention so that my next move
Im located in the Austin area....DelValle to be exact,
PostPosted: Fri May 02, 2014 5:47 am
Is it a flapper door or hot wire style?
The flapper door style can be adjusted. You have to pop open the black plastic cover, and inside it has a sawblade looking wheel that you can turn either direction a notch or two. I can't remember which way is lean and rich though. I bet you can look up some threads online about adjusting 7M AFMs.
1977 Celica coupe
1989 Cressida
PostPosted: Fri May 02, 2014 5:48 am
If it looks like someone has been into it and adjusted it in the past, it may be way off.
1977 Celica coupe
1989 Cressida
PostPosted: Fri May 02, 2014 5:53 am
JZcelica...thanks for the advice!!
its a flapper door type sensor, i have been playing with the idea of removing the cover and messing with it...i think ill try that this weekend and post the results.
PostPosted: Sat May 03, 2014 10:29 am
If youre going to adjust the AFM, be sure and do it with a voltage meter, so you can set it to the correct output voltage to the ECU. It's probably 0 - 5v variable.
1977 Celica coupe
1989 Cressida
PostPosted: Mon May 05, 2014 7:44 am
Got it!. thanks.
PostPosted: Fri May 30, 2014 7:23 am
opportunity is knocking again....so i am listing the Mark II for sale in the hope that i can take advantage of the opportunity...Please PM or call/text me (512-767-0644) if anyone has interest in the car.
PostPosted: Fri May 30, 2014 10:05 am
10psitx wrote:
Where im at so far
ill-minded wrote:
The wheels are SSR Longchamp XR-4Z, by the way. :)
The build plate should state whether it has an 8" (G series) diff as well. It's located next to the gearbox code usually.
seems like you have a G final drive...
I've done EXTENSIVE port work on 4AGEs (very similar to 1GG)... if you come across a spare head I'll be happy to make it flow better
Information = POWER
PostPosted: Fri May 30, 2014 11:19 am
oldeskewltoy wrote:
10psitx wrote:
Where im at so far
Thanks man...its Very tempting, but i'm trying to sell it.
PostPosted: Tue Jul 01, 2014 9:15 am
The radiator had a leak on the top tank so i ordered one for a Cressida...i havent installed it yet hope fully this weekend. I haven't worked the car in a few months....i start it drive it to the end of my street and back, so this weekend its getting some love!!
PostPosted: Wed Jul 16, 2014 9:48 am
The A/C in the house needed to be serviced so i took some time off from work to meet the A/C tech today, while waiting i decided to change the Radiator, well took me all of 15 mins to pull everything but after seeing the condition of the rad hoses i thought it best to replace them as well....so i will order some silicone ones. I removed the MAF a few days ago to send to Cali for service so the "rubber" intake tube was in the way of the lower rad hose, i sorta twisted it to gain some space and it broke right where the clamp is on the turbo intake pipe, i need to replace that as well.... Some pics....
Broken Intake tube
