It is currently Fri May 22, 2015 9:21 pm
 Post subject: Chassis question
PostPosted: Mon Jan 27, 2014 3:48 pm
Is the ae70 the same as the ae72? besides one is right hand drive and the other is left a seller on eBay is saying lowering springs for ke70/ae70 won't fit the ae72?
 Post subject: Re: Chassis question
PostPosted: Mon Jan 27, 2014 8:06 pm
Are you saying that the Seller claims the springs fit either KE70 or AE70? If so you should be fine.
PostPosted: Mon Jan 27, 2014 8:31 pm
They are brand new lowering springs for the ae70 or ke70 on eBay they are called king springs they are out of Australia I looked up king springs and on there web site they have lowering springs for the corolla does anybody know about these in Australia ?
PostPosted: Mon Jan 27, 2014 11:19 pm
I believe the ae70s come with rack and pinion steering. Springs /struts should be the same if you are talking aftermarket.
PostPosted: Tue Jan 28, 2014 9:19 pm
Yes. They will fit. Most of your Toyota struts were 51mm, especially on the same chassis code a7x, the big difference is engine, and body (coupe, liftback, more door). Underpinnings usually stayed the same, I know on later Corollas like the hachi, and on my second gen Celica, they did.
PostPosted: Thu Jan 30, 2014 1:31 pm
from memory(may be faulty)... they may not.... the strut mounts changed in mid production, 1980, and 81 models have a slightly different upper strut mount than the 1982-83 - this I know for sure. What I'm uncertain about is I seem to remember one of the spring seats on the struts changed a little too... this would mean the earlier springs don't fit the later models.... but this I'm uncertain about....
From Toyodiy....
48131 SPRING, FRONT COIL, RH
48131-12710 (08/1979 - 07/1981) 1 $132.60
48131-1A120 (08/1981 - 07/1982) 1 $125.59
48132 SPRING, FRONT COIL, LH
48131-12730 (08/1979 - 07/1981) 1 $145.24
48131-1A130 (08/1981 - 07/1982) 1 $126.12
Information = POWER
PostPosted: Fri Feb 07, 2014 4:54 am
Yes the King Springs do fit both KE70 and AE71.
Cheers Brett.
