It is currently Tue Jun 30, 2015 9:56 pm
Post a new topicPost a reply Page 1 of 4   [ 75 posts ]
Go to page 1, 2, 3, 4  Next
 Post subject: back into the '74 SR5 project
PostPosted: Sun Dec 08, 2013 6:14 pm
Hey all...as I mentioned on the intro page, I recently have returned to my resto project on my '74 TE27 SR5. she has sat in my garage for 4 years now with minimal work done. I started stripping the underside last year and have decided to focus completely on finishing that as well as all wheel wells, struts, linkages...etc. I will be looking for guidance from the forum knowledgeable ones being that this is my first time at something like this. due to a series of mishaps, I have no pics of the car as she looked when I rescued her from the ranch where she had been sitting at for the past 15 years. 88K miles, engine sounds good, have driven around the local streets and it runs good with a bit of a shimmy problem due to a dented drive shaft. I would love to post some pics directly here but get the following message...Sorry, the board attachment quota has been reached.....any suggestions to get around this? till than recent pic on the link.
http://s1346.photobucket.com/user/sweav ... d.jpg.html
latest progress.
starting the underside painting.
1974 TE27 SR5
1974 TE27 SR5 rustbucket
1974 TE27 to be SR5 clone
1973 RT89 Corona wagon
1969 RT52 Corona 2 dr coupe
 Post subject: Re: back into the '74 SR5 project
PostPosted: Mon Dec 09, 2013 7:41 am
8) whats under the hood ?
Charmant A45, A60
Corolla KE17, KE35, TE38
Laurel C30
PostPosted: Mon Dec 09, 2013 12:10 pm
stock 1600 2TC. game plan is to bring back car completely stock at first....once she is on the road and registered, who knows.
1974 TE27 SR5
PostPosted: Mon Dec 09, 2013 9:27 pm
I will be watching this one. I am doing the same thing with my TE27, but with more issues to sort out. Good luck with build feel free to PM with any questions.
1974 TE27 White #1
1974 TE27 White #2
1975 TE38 Brown
PostPosted: Sat Dec 14, 2013 7:48 am
This weeks work....
Harbor Freight tool worked great separating the linkages.
1974 TE27 SR5
PostPosted: Sun Jan 05, 2014 5:56 pm
Deep into the seat rebuild. pulled passenger seat back springs off and will transfer to driver side which has 3 busted support springs. discovered broken weld at bottom of frame, will get rewelded.
Latest on seats....grant from NZ has completed the skins for my front and rear seats and is now working on fabricating some replacement foam and also some replica door panels. will post pics once all back together.
here is the completed seats as of this past weekend.
1974 TE27 SR5
PostPosted: Sat Feb 08, 2014 7:42 pm
Next phase, just pulled engine/tranny. going to clean/strip/prime and paint (or powdercoat) engine bay, put engine back in and take it to Ray at RaceToys in Diamond bar for a rebuild/upgrade. Looking at 3tc cranks, dual carbs and whatever else he wants to throw in. Still trying to get it done by its 40th birthday in June.
1974 TE27 SR5
PostPosted: Fri Feb 14, 2014 1:34 pm
Sweet project...im doing the same thing to mine. I'm almost done. A little advise strip EVERYTHING in engine bay.... then paint.... I have pics on my rebuild on the 3tcgarage site....I also am trying to finish by my 40th in Sept....lol
PostPosted: Sat Feb 15, 2014 7:18 pm
Something about them 27's...
1974 TE27 White #1
1974 TE27 White #2
1975 TE38 Brown
PostPosted: Mon Feb 17, 2014 8:31 pm
toyorotor: I just checked out your build at 3tc.....very nice, love the color, I am thinking of House of Kolors Oriental Blue. Very cool that you have a similar project a few paces ahead of mine, I may be contacting you from time to time for advice. I have not been able to locate rubber for 1/4 windows...any thoughts?
1974 TE27 SR5
PostPosted: Thu Feb 20, 2014 2:36 pm
Quarter windows came from Cabe Toyota I think in Cali.... or maybe ebay... but you'll find them. I got the front n rear from ebay, But I don't like the way they sit. I don't know if they need to sit in the sun to flatten out, or they are just cheap aftermarket.....
PostPosted: Sun Mar 02, 2014 8:12 pm
After weeks and weeks of grinding and sanding I have just completed the undercoating. Fairly happy with the way it came out. This is the KBS system and sprayed on with a 1.4 harbor freight gun. I did not order the thinner for this Rustseal and it sprayed thick....did not come out of the gun smooth and left a light texture to the finish which I actually like. First time using a HVLP gun and the laying on back spraying straight up was the challenge. Next weekend it is the painting of the engine compartment so I can get the engine back in.
1974 TE27 SR5
PostPosted: Sun Mar 16, 2014 5:25 pm
latest progress
last weekend I painted the engine and trunk with the exterior PPG blue paint and had a couple mishaps...changed the game plan, doesn't make much sense to paint engine bays with paint. I went with the same KBS coating I used on the underside.....dries like ceramic, does not chip or scratch, much more fit for the engine and trunk.
1974 TE27 SR5
PostPosted: Fri Apr 11, 2014 6:15 pm
Progress looks good! Those seats look great!
1974 TE27 White #1
1974 TE27 White #2
1975 TE38 Brown
PostPosted: Sat Apr 12, 2014 8:55 pm
thanks skell...and this is the engine compartment redone with same KBS coating as underside.
1974 TE27 SR5
PostPosted: Sun May 18, 2014 3:07 pm
beginning the process of reassembly. starting with rear end suspension. picked up a HF sandblaster and used for the first time on the T50 10 bolt rear end. wish I got this about 100 wire wheels ago....now I know. goal of completion by June is long gone, I am now slowing things down and trying to get everything right the first time.
1974 TE27 SR5
PostPosted: Mon May 19, 2014 5:38 pm
Very well done. :tu: :mrgreen:
PostPosted: Mon May 26, 2014 7:28 am
engine is going back together. attempts at getting it rebuilt/modified are on hold. going back to plan A....get it back in, running and registered than look into adding some oomph.
1974 TE27 SR5
PostPosted: Wed Jun 18, 2014 1:43 pm
Sweet Resto :tu:
Looking and Dreaming:
73 Te27 SR5
PostPosted: Sun Jun 22, 2014 2:19 pm
thanks padillz.....latest update. SR5 turned 40 this month and I was wanting to get it something special.....after much thinking decided on the following:
I hope it likes it.
1974 TE27 SR5
Users browsing this forum: PathFindeR and 1 guest
