It is currently Sun Mar 01, 2015 8:38 pm
 Post subject: mx73 intermittent blower motor problem.
PostPosted: Fri Nov 15, 2013 4:11 pm
Figures that as soon as it starts getting cold and wet my blower motor would start acting up. Its been doing it for a few weeks, the first time it cut out, I ignored it for a few days, and then on my way to work one day, I hit a big bump, and it turned back on. Worked fine for a few days, then gut out again. So I reached down and thumped the side of the blower motor, and it turned back on. Well, it's cut out again, and I can't get it to start working again. I was thinking maybe a resistor, but it seems that most of the time when a resistor is bad, it will work on certain settings and not others. Any input? I suppose it could just be the motor itself, but neither part is very cheap, so input would be greatly appreciated!
 Post subject: Re: mx73 intermittent blower motor problem.
PostPosted: Sat Nov 16, 2013 8:50 pm
I'm going to bet it's the motor. I've had several blower motors go bad, but never a resistor. Since hitting the motor itself made it work, that's probably the culprit.
The definitive way to tell is to check for voltage at the motor with a multimeter. If there is voltage but no spinning, it's the motor. If the switch is on, but no voltage, it's something in the circuit.
2 Timothy 1:9-10, Ephesians 2:8-10, Psalm 91
88 Corolla Sedan
86 Corolla GT-S
73 Corolla 2 Door Sedan
http://www.superhachi.com
PostPosted: Sat Nov 16, 2013 10:18 pm
Sounds more specifically like your brushes are bad. They are a wear part and once they get short enough, they just don't make contact. Either that or a loose wire. My heater switch would act up without pattern until it finally quit and I had no defrost when the weather turned. On the back of the switch I felt a loose wire which turned out was moving in and out of contact depending on switch position and bumps in the road.
PostPosted: Sun Nov 17, 2013 11:12 am
It was the motor :). Thanks guys!
PostPosted: Tue Dec 03, 2013 9:37 am
Could the blower only coming on when you hit "Auto" but not when you hit "high" or "low" be the motor itself?
PostPosted: Tue Dec 03, 2013 2:10 pm
I have a similar problem except it is just low that doesn't work.
There is only one blower doing all the work right?
PostPosted: Mon Jan 06, 2014 7:29 pm
That's a different thing that causes that. I forget what it's called, but there's a large sensor that has 2 or 3 coil element that mounts right next to the fan near the heater core. It's a common problem because crap get's in there and damages the elements. Mine is bad too, but it's was unrelated to the fan not working entirely.
