It is currently Sat Apr 25, 2015 2:02 am
Post a new topicPost a reply Page 1 of 3   [ 42 posts ]
Go to page 1, 2, 3  Next
 Post subject: TE51-Panic!
PostPosted: Fri Oct 11, 2013 12:03 pm
Hey my name is Matt from Seattle, WA. I have a TE51 sport coupe as my 2nd daily driver. Basically when it's not raining out I drive it to work and stuff. My other daily is an SC400 but I don't really like it. It's too new :)
So far I have spent a little time fixing holes in the floor and making the interior nicer. It has a couple of cool things like nardi wheel and watanabes. The front has ae86 coilovers which I'm happy with but the rear is leaf spring and not low enough. There are blocks in there now but I don't know much about leaf springs. Any advice on making the back lower? Also, the window seals leak and I can't find new ones. Do they even exist?
Pics:
 Post subject: Re: TE51-Panic!
PostPosted: Fri Oct 11, 2013 12:07 pm
Interior stuff I have been working on:
I don't know anything about carbs so my friend is putting together a fresh 3tc for me. I'm just going to keep it stock.
It's getting colder here now and I don't have heat. I'm thinking to just get a universal heater from summit.
http://www.summitracing.com/parts/sum-9 ... /overview/
Thoughts?
PostPosted: Fri Oct 11, 2013 1:08 pm
Welcome Matt... NICE Corolla :tu:
Part of why Toyota used the trailing arms in the E7 and AE86 was the leaf springs are inherently less versatile. About the only way to get the rear of your car down is with blocks. As far as handling... check the condition of the leaf spring bushings... if the leaf is twitching in its bushings that isn't good.... also Addco still shows availability on sway bars.
Information = POWER
PostPosted: Fri Oct 11, 2013 8:12 pm
Very nice!! I want one so bad.
PostPosted: Fri Oct 11, 2013 11:21 pm
Very nice car! Love these models.
PostPosted: Sun Oct 13, 2013 5:53 pm
Such a cool little coupe!! 8)
I've got the JDM sister to your model. They're really great little classics...
Love the colour on yours and she sits nicely on those Wat's! What size are they - 14" or 15"??
Keep up the good work... :wink:
Best Regards,
Anders.
PostPosted: Mon Oct 14, 2013 6:27 pm
Thanks! My wats are 14". I'm going to try to make the rear lower this week.
PostPosted: Wed Oct 16, 2013 1:35 pm
NICE !
PostPosted: Thu Oct 17, 2013 4:52 am
Let me know how you go with that!
I'll soon be doing the same to my TE61...
Best Regards,
Anders.
PostPosted: Thu Oct 17, 2013 4:47 pm
Looking good! I really love the Watanabe's but I'm not a huge fan of the steering wheel.
PostPosted: Fri Oct 18, 2013 6:06 am
Nice wheels!
The Black Cat - S800M Coupe.
PostPosted: Fri Oct 18, 2013 10:30 am
Hey Matt, you can take your car to an old-school spring shop and see about having them make you some custom leaf packs but it will end up being expensive. There was one shop close to me that didn't look at me funny when i gave them the make and model of the vehicle i was inquiring about, and even when i gave them my spring dimensions they brushed me off though.
you might consider swapping in a different rear end with coils and making your own perches, but since it's a daily im not sure how much work you want to put into it.
im sure youre no stranger to that type of work though
PostPosted: Fri Oct 18, 2013 11:28 am
Thanks for the comments everyone :D
Thanks for the info. I'm going to try and flatten my primary leafs with a press this weekend. I have a complete rear end from my RA21 that I could swap in. This car isn't for the track so I don't really want to cut into it too much. I don't know how this leaf spring stuff is going to work out. I'll post pics and a write up of how I did it. Worst case I'll just figure out coilovers or something I'm more familiar with.
Also, I bought a heater from summit. I'll be installing that this weekend as well if it gets here in time.
PostPosted: Sat Oct 19, 2013 6:02 pm
Ok so I played around with this thing today. Here's a pic of the gross 3tc since I haven't posted one:
I used some spacers to make the offset more acceptable:
It turns out the blocks I have are only 2.5". I think 4" will make it looks just right. Does anyone know a good place to buy 4" blocks?
So since I didn't mess with the rear springs I had some extra time. The rear bumper is short like the front now, much better 8)
My heater won't be here until Wednesday so but that's the next thing. It's getting cold up here.
PostPosted: Sat Oct 19, 2013 6:31 pm
Nice bumper mod. Looks nice tucked in closer like that. Which way did you do it? You make brackets? or put a bolt through the absorber?
PostPosted: Sat Oct 19, 2013 10:49 pm
car looks good! interior looks phenomanal. love the color too, and especially on the black watanabes. I would like to buy a set for my te51 eventually. it seems like every other sportcoupe I see only makes mine look shittier haha
personally, I would not go with 4" blocks. I have 3" on mine, and I wouldn't want to go any more. it's like driving on high heels. I'll take some pics, but I have about 2 inches of clearance in the rear. I still want to go lower, so I'm just going to have the spring eyelets flipped. it will be equivalent to a 1" drop. a local spring shop quoted me $75 each spring. also, I bought my blocks from amazon. all I had to do modification-wise was widen the hole on the bottom of the block.
also, window seals are non existent for our cars. you'll need seal it some other way. I believe another te51 guy on here replaced his seals, can't remember his name. mine are cracked as well, but we don't get much rain out here in Arizona, so I'm not worried about it.
-Nick
TE51 SR5
A187 GSR-VR
JDL Auto Design
PostPosted: Tue Oct 22, 2013 6:06 pm
Thanks for the input. I'm just going to make my own blocks to get it just right.
It's almost time to assemble the new 3t :)
I got a little bit better clutch in case I want to do burnouts lol
The new heater will be here tomorrow. I'll try to get some pics of the install.
PostPosted: Wed Oct 23, 2013 11:04 am
watch your clearance under the lower shock mounts when you put bigger blocks on the car. they will probably scrape on anything and everything.
PostPosted: Wed Oct 23, 2013 6:33 pm
Cool car.
How does spray painting interior parts look after a year or two?
kolxoz
PostPosted: Wed Oct 23, 2013 6:42 pm
Matches wrote:
Cool car.
Thanks :D
I don't know yet, it's only been a month or two. In the picture the paint was still wet. It's actually flat black which matches the dash pretty well.
