It is currently Wed Jan 28, 2015 11:30 am
Post a new topicPost a reply Page 4 of 5   [ 94 posts ]
 Post subject: Re: Across the country in a 73 Wagon
PostPosted: Fri Mar 15, 2013 10:11 pm
Looking good! AMG spark plug cover fits nicely with that hyundai valve cover!
91 Galant VR4 1350/2000
76 Colt Galant Coupe
75 Colt Galant Wagon
77 Colt Galant Wagon
PostPosted: Tue Apr 02, 2013 7:13 pm
good news; ordered a new set of front wheels so i can slam the front, get rid of my wheel gap!
in the mean time; had to chase down my brake lights and rewire them, system failed in the turn signal switch, but it gave me the change to create independent brake lights, segregated from the turn signals, might add a 3rd brake light now.
getting her ready for some warm weather:
1991 Mitsubishi Galant VR4
 OnlineProfile
PostPosted: Thu Apr 04, 2013 1:50 am
Glad the rewiring trick worked out!
Warm weather has already arrived in the PNW now :mrgreen:, low 60s and sun here! 8)
PostPosted: Mon Apr 22, 2013 8:15 pm
finally lowered the front...
 OnlineProfile
PostPosted: Mon Apr 22, 2013 10:36 pm
:tu: :tu: :tu:
http://www.70scoltgalant.com/
PostPosted: Sat Apr 27, 2013 6:27 pm
went out exploring with the lady
 OnlineProfile
PostPosted: Tue May 07, 2013 5:38 pm
the girl and i went out driving around and stopped to take some pics. seems like im better with an iphone than i am with a DSLR these days...
 OnlineProfile
PostPosted: Fri May 17, 2013 7:06 pm
converted it to GM MAFT to clear up the engine bay
washed it today.
 OnlineProfile
PostPosted: Sat May 18, 2013 9:31 am
Why not just go SD?
PostPosted: Sat May 18, 2013 10:50 am
this was cheap and easy. Spend under $80
 OnlineProfile
PostPosted: Sun Jun 09, 2013 11:27 pm
we need to have a indiana classic import meet ! :mrgreen:
Matt
71' Celica ST 54k - under rust repair
98' z28 - daily gas hog
PostPosted: Wed Jun 12, 2013 6:27 am
I'm down for that!
Drove up near Detroit for a car show over the weekend and a magazine called Arson Capital did an interview with me and took some shots of my car. :D
 OnlineProfile
PostPosted: Mon Jun 17, 2013 1:07 pm
Transmission upgrade time:
Over the weekend I bulked up to the 132 transmission. Details:
Donor: 1988 Mitsubishi Mighty Max, 2 liter, 2 wheel drive, cable driven clutch
Parts needed for swap from my KM119:
-clutch is exedy:
PART NUMBER: MBD901U
DISC DIAMETER: 9-1/16" (225 mm)
SPLINE DIAMETER: 1" (25.4 mm)
SPLINE COUNT: 23 spline teeth
-KM132 trans
-early evo/gvr4/eclipse flywheel machined for pilot bearing
-early evo/gvr4/eclipse pressure plate
-mighty max pilot bearing
-clutch disc from v6 eclipse (listed above) disc spline is different diameter and number than the early evo/gvr4/eclipse
depending on the year of the transmission you may need the front yoke of them mighty max driveshaft 86 or older, same as colt, 86 or newer, larger diameter. Mighty max driveshafts have the same diff mounting flange though so instead of swapping the yoke you could have a driveshaft shop shorten the mighty max driveshaft (beefier tube but too long) otherwise, it's a good chance to replace the ujoints in your stock driveshaft (same as mighty max)
difference between KM132 (left) and KM119 (right) clutches. Oddly enough the clutch was likely slipping due to 3 of the pressure plate bolts being loose, i had been running solid motor mounts for a few months (as in solid steel to chassis) and im guessing it rattled some shit loose. So the clutch might hold up to more than I thought.
The first thing you notice when comparing the KM119 to the KM132 is just how small the KM119 is, it's obviously the dirty one (oil leak from back of valve cover) but it's very narrow compared to the 132.
this is another dead give away for which trans you have, note; shifter location and overall length of transmission is still identical to the KM119
here the only difference to note is the different input shaft diameters:
Also note: the trans pans are different, so a Tuffpans reinforcement plate for a 132 wont work on a 119
All in all, start to finish, it was a single day project, the KM119 has no bearing play, fluid looks good and the clutch was likely slipping due to loose pressure plate bolts, it's currently unknown how much power a KM119 will hold, my room mate might put the trans into something and Im certain we will soon find out how easily a KM119 does break. :thumpsup:
 OnlineProfile
PostPosted: Mon Sep 23, 2013 6:13 am
 OnlineProfile
PostPosted: Mon Sep 23, 2013 12:30 pm
Nice ride!
And very interesting write-up about the gearboxes! Thanks! Maybe you can also post this on SG?
PostPosted: Mon Sep 23, 2013 5:40 pm
I posted it on SG in the trans tech section. No one over there gave a crap :roll:
 OnlineProfile
PostPosted: Mon Sep 23, 2013 6:31 pm
Does your lady drive the 4dr?
PostPosted: Tue Sep 24, 2013 4:17 am
pitty, because I had a question about the differences a while ago, but it was in the chatroom of SG. I wasn't sure which one I have but thanks to your write up here I now know for sure it's a KM132.
PostPosted: Wed Sep 25, 2013 7:56 am
Yessir, all summer long. :tu:
 OnlineProfile
PostPosted: Wed Sep 25, 2013 7:59 am
that chat should be removed, it does no one any good, doesnt archive information and can't be searched. just a waste of space and info.
 OnlineProfile
Users browsing this forum: incorporatedx and 2 guests
