It is currently Fri Jul 03, 2015 9:28 pm
 Post subject: 1981 Toyota STOUT
PostPosted: Wed Sep 18, 2013 7:03 pm
This is my 1981 Stout
Engine is not te original 5R. Now has a Toyota 2L 2.4 Diesel and a 5 speed
http://s367.photobucket.com/user/seis_6 ... ta%20Stout
Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image
1979 Toyota Cressida GL Hardtop
1980 Toyota Cressida GL Hardtop
1981 Toyota Stout
 Post subject: Re: 1981 Toyota STOUT
PostPosted: Thu Sep 19, 2013 6:51 am
Very cool! What kind of output do those 1C diesels make?
PostPosted: Sun Sep 22, 2013 9:05 am
I don't know the original vehicle of the 2L engine comes from
But wikipedia says:
2L
The 2L is a 2.4 L (2,446 cc) 4-cylinder diesel engine. Bore is 92 mm and stroke is 92 mm, with a compression ratios of around 22.3:1 and redline of 4800 rpm. Outputs range from 76 to 87 hp (57 to 65 kW) and torque of 15.8–16.8 kg·m (155–165 N·m).
Applications:
Mark II/Chaser/Cresta (85 hp or 63 kW at 4,200 rpm, 16.8 kg·m or 165 N·m at 2,400 rpm, 22.2:1)[2]
Hiace
Hilux (83 hp or 62 kW at 4,000 rpm, 15.9 kg·m or 156 N·m at 2,200 rpm, 22.3:1)
Dyna
Kijang Fourth Generation
1984–1990 Blizzard LD20 (76 hp or 57 kW at 4,000 rpm, 15.7 kg·m or 154 N·m at 2,400 rpm, 22.3:1)[3]
1981 Toyota Stout
PostPosted: Sun Sep 22, 2013 8:06 pm
The 2L diesel motor is a beauty! :D i had one in my 1988 2WD Hilux. They usually have those massive oil filters on them, and have a very safe rev range, so they last forever. I miss my ute... :cry:
"Ah, how the passion runs thick through our veins"
PostPosted: Wed Sep 25, 2013 5:29 am
1981 Toyota Stout
