It is currently Wed Mar 04, 2015 12:06 am
 Post subject: 4ac to 4age
PostPosted: Wed Jul 31, 2013 3:31 pm
Is there any bolt on between the motors like exhaust manifold or exhaust system I have an 1983 sr5 liftback and I'm looking at exhaust systems for it it is the same block no?
 Post subject: Re: 4ac to 4age
PostPosted: Wed Jul 31, 2013 3:36 pm
Same block, but completely different head. Hence, completely different parts for headers and such
1985 MX72 soon to be...
PostPosted: Wed Jul 31, 2013 3:55 pm
How much would I need to convert over besides motor and ecu?
PostPosted: Thu Aug 01, 2013 6:12 am
Motor
Harness
Ecu
Fuel pump
Fuel lines
Transmission bell housing or 4AGE T50
Clutch lines
Slave cylinder
PostPosted: Fri Aug 02, 2013 10:43 am
What's an easier set conversion 4age or a 3tc set up?
PostPosted: Tue Aug 06, 2013 7:08 am
dude. going from carb engine to carb engine means you don't have to deal with swapping the fuel system. other than that it's the same thing. "easier" is a subjective thing, might be a weekend and a case of beer for one guy or a month-long headache full of forum hand-holding and ending up with trailering the whole thing to a shop and having them finish it for another. you seem like you're in danger of becoming the latter.
google is your friend:
http://www.dorikaze.net/showthread.php? ... -into-AE86
GTS swaps into SR5 cars are seriously well documented in many places.
PostPosted: Fri Aug 09, 2013 7:27 pm
3tc is the cheaper route unless you can score a gts donor car for cheap which are hard to come by as parts pull a premium. Keep in mind that even if you pick up a 4age off an mr2 for cheap there is a few parts that are needed to convert to rwd. Do your homework as it can get expensive. Good Luck. Any pictures of car.
Users browsing this forum: ansarghani, Yahoo [Bot] and 2 guests
