It is currently Fri May 22, 2015 9:25 am
Post a new topicPost a reply Page 2 of 3   [ 41 posts ]
 Post subject: Re: Gray Panda GT-S 16v Hatch Build
PostPosted: Tue Feb 11, 2014 4:12 pm
Got to see the pistons in the motor and rotating this weekend, assembly should be finished soon. Ordered some no-name 10 inch fans and picked up some silly JDM bling at the post office today that I just couldn't resist:
Rain visors, whattt?
PostPosted: Thu Feb 13, 2014 12:27 pm
sweet pickup man. post em when they're on the car!
PostPosted: Tue Mar 11, 2014 9:51 am
Yay, more eBay parts are in.
10 inch fans and some switchgear.
As for the motor, here's the updates:
    Every single component has been thoroughly cleaned
    Rings chamfered
    New woodruff key
    Bottom end is all together, head/valve covers on
    Timed to factory
    Oil drain back added from head to pan
    Injector connectors replaced
Getting there, can't wait to hear it run.
PostPosted: Tue Mar 11, 2014 3:39 pm
Cool project. Thanks for sharing
kolxoz
PostPosted: Tue Apr 01, 2014 8:04 am
Quick update time.
Turns out my goofy oil pressure warning light sensor fouled the PS pump. So, with that in mind along with the plan always being to switch to manual rack, we did just that.
Here's the AW11 rack (sans u-joint which came in later) complete with totally shagged inner tie-rods:
T3's bitchin' manual rack parts along with a fuel pressure gauge:
Here's the rack in the car:
On the motor front, everything is all together and in the car.
Here's the sweet new oil drain-back in place:
New flywheel and bolts:
And with the new clutch kit:
Fancy new intake gaskets:
Fuel setup with new connectors, refreshed injectors, etc.:
Here's the motor and trans before they went in:
So, what remains now is fixing the wiring the previous owners absolutely FUBAR'd, shrouding and mounting the new 10 inch fans, mounting and wiring my overkill digi-gauges and warning lights, breaking it in, then figuring out what is the next most critical area of concern once the engine is sorted. Getting close!
PostPosted: Wed Apr 02, 2014 5:47 pm
You may want to check the bush on the right side of the AW11 rack.
They were known for wearing and making a terrible rattling/knocking noise.
PostPosted: Wed Apr 02, 2014 5:59 pm
Solid tip, thanks!
PostPosted: Wed Apr 09, 2014 8:08 pm
So, the wiring was bad:
Now it's good:
The battery relocation cable was just coiled up and run through the firewall (see the ratsnest in the before pics above), now it's routed properly:
The ignition coil was laid down (see the ratsnest in the before pics above), not it's upright on a sweet mount:
PostPosted: Thu Apr 10, 2014 6:20 am
yeah, build a badass custom harness. remove the unnecessary stuff, tuck it where possible. toyota uses a lot of connectors on different cars so making a couple junkyard trips should score you what you need on that end.
PostPosted: Thu Apr 10, 2014 8:29 am
comming along quite nicely...can you share a little more on the manual rack convo?
PostPosted: Thu Apr 10, 2014 8:42 am
Thanks.
So, the manual rack is something I wanted to do in the long run anyway, and as the pump fouled on one of my new sensors, we decided to do it now.
What you need is a manual rack from an AW11 MR2 (getting hard to find), the u-joint from the same car, a bushing that fills in the gap between the larger PS rack and manual rack (T3 sells one), and an intermediate shaft either from a MK3 Supra (getting hard to find) or a new one from T3. The inner tie rods on the MR2 rack I got were totally loose, so we had to throw on some other ones. I didn't splash out for the fancy tie rod ones you can get.
PostPosted: Thu Apr 17, 2014 10:04 am
Mad Max style!
Sweet new fan shroud the builder fabbed for the eBay rad and eBay fans:
Interior coming together with warning lights, gauges, cutoff, etc.:
Everything's coming together, just some wiring and break-in left... hopefully!
If anyone has some lower radiator mounts/bushings/grommets/supports/insulators/whatever-they're-calleds, hit me up.
PostPosted: Sat May 10, 2014 9:28 pm
So, the good news is the car is home, it's running, and it's even inspected. Motor feels great, especially over 4k.
Here she is passing inspection.
Engine has been broken in, rings seated, and 200 mile oil change has been preformed. The fans have been wired up with a switch and relays, the gauges and warning lights are wired up, along with the battery cutoff.
Here you can see the fan switch (silver toggle), battery cutoff, warning lights, and gauges:
There's also a mini fuse box for all this hidden in the ash tray.
The booty HVAC panel was well past it, so we sourced a new one along with replacement knobs. The stupid brass Autometer adapter for the oil pressure sender failed under the weight of the big Autometer sender, so it had to be moved to the oil pump. The alternator was bad, so that was replaced with a re-manufactured item:
The taillights were full of water, which explains why the brake fuse was blown, which explains why the brake lights weren't working. Love when it's this simple to diagnose a problem.
The not-so-good news is the heater core was cracked, so it's been looped for now. Also, there's a fault or loose wire on that funky fuse box you can see above that requires you to give it a firm tap before the car will start (WTF?). Plus, the fuel damper has sprung a leak, the clutch slave cylinder is worn, and the fuel filter needs to be moved back towards the firewall (previous owner must have yanked the hardlines). Luckily, none of those are major showstoppers and hopefully these creases are ironed out soon.
Chillin' with the Cressida:
PostPosted: Wed May 14, 2014 7:42 am
going for a good restoration ae86
looks good :tu:
PostPosted: Thu May 15, 2014 3:38 am
Congrats on the inspection.
Job well done.
Now just get out there and drive her!! :P
And keep us posted as you get the detailing right...
Best Regards,
Anders.
PostPosted: Thu May 15, 2014 4:57 am
Good progress. Can't wait to see it all finished up. Been toying with the idea of getting one but already have too many Toyotas in the household.
1984 Toyota Crown: 6M-GE swap in progress
1988 Toyota Hilux: getting worked back to life
PostPosted: Thu May 15, 2014 7:31 am
Thanks guys, means a lot.
PostPosted: Wed May 21, 2014 8:14 am
We swapped out the power block, so the electrical fault is fixed. We swapped out the fuel damper so it's no longer spraying fuel everywhere. It has a small oil leak, but beyond that it's driving well!
1985 driveway life:
Chillin' outside:
PostPosted: Sun Jun 08, 2014 11:24 am
Lightest hood on the market:
New used hood looks... pretty hood. At least it's straight!
At least it looks pretty sharp from this angle, I suppose.
PostPosted: Sat Aug 09, 2014 8:51 am
Chillin' at Houston 86 Day.
Users browsing this forum: Yahoo [Bot] and 7 guests
