It is currently Thu Mar 05, 2015 1:08 am
Post a new topicPost a reply Page 1 of 7   [ 138 posts ]
Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: 1986 MX72 Cressida Wagon Build: "Joby"
PostPosted: Thu Jul 18, 2013 3:28 pm
Copy-pasted from another forum for your viewing pleasure:
6/9/13
Picked up this poor thing from a guy up in NoVA on 6/9 for $600. It has 158k miles, leaks pretty much every fluid, needs a battery, supposedly overheats (it never did for me), the paint is TERRIBLE, the left rear door doesn't open from the outside, the front right window won't roll down from the switch on the driver's door (never tried the pass. side switch), but the interior is in almost PERFECT shape, and it runs. And it's (more or less) a Celica-Supra wagon!
Here's the service history I have for it.
6/23/98 - 106k
Rear brake shoes & wheel cylinders
6/30/98 - 106k
Battery
7/9/98 - 106k
Emissions fail
7/15/98 - 106k
Air filter, spark plug
8/26/98 - 107k
Front struts, alignment, rotation
9/22/98 - 109k
Transmission service, antenna mast, wheel balance, front wheel bearings
4/27/99 - 115k
Water pump
6/18/99 - 117k
Radiator fan
10/19/99 - 121k
New (used) distributor + spark plugs
1/3/00 - 124k
Plug wires
3/17/00 - 125k
R&R tail shaft housing/diff
3/21/00 - 126k
"Differential assembly/rear susp" + gear oil??
8/24/00 - 130k
Left rear wheel bearing
8/25/00
Catalytic converter
3/22/01 - 137k
Rear muffler
7/18/01
Oil change
10/1/01 - 141k
Neutral safety switch
Right now my plan for this car is to remove the engine and transmission and re-seal everything out of the car. This will make it WAY easier I think. I would LOVE to do a manual swap but parts will be hard to find locally and cheaply. It needs a W58 transmission/shifter/slave cylinder from a MA70 Supra, a W58 from any other car has the shifter in the wrong position. I would then need an MA70 flywheel and clutch kit, as well as an AE86 Corolla clutch pedal, MA60 Celica-Supra master cylinder, and I would have to custom make a hard line, and add in a stainless soft line. Then, the drive shaft needs to be re-sized to fit (I don't remember longer or shorter). Then the big issue is getting the speedometer to work. Still not clear on how that happens.
6/11/13
In talks with a SupraMania member in Fredericksburg about picking up a Supra W58 with around 130k for $200 if it has the slave cylinder, $175 if not.
6/12/13
OK so I plan to pull the engine and replace pretty much every gasket and seal in the motor, I have a couple options.
1) Super cheap no-name brand rock auto kit - $100
2) medium priced rock auto kit made by the same parent company as FelPro - $150
2.5) the above kit + oem head gasket for quality where it really counts - $230
3) the LAST later-generation 5M-GE OEM complete engine overhaul gasket kit in the country from Toyota - $318
EDIT: Holy hell, shipping for that kit on rockauto is like $20, bringing the total to $167. I googled the SealedPower part number and Summit Racing has the same kit for $110 with free shipping. I think I'll do that.
6/14/13
Picked up the row-your-own gearbox today. $250 got me a W58 5-speed manual trans from a 1986.5 Supra complete with shifter/boots and reverse light switch, two used clutch/pressure plate pairs, a flywheel, a brown shift boot to match my interior, and a stock Supra shift knob. And I discovered that the Cressida's driveshaft will in fact spline up into the W58. WIN.
6/16/13
So the left rear door wouldn't open from the outside. I got bored and took 15 min to remove the door panel and have a peek inside. This is what I found
Turns out this little plastic clippy thing had broken and couldn't hold the rod in the handle anymore.
So I took it off, put a zip-tie on the end of the rod, and now the door opens from the outside. Aww yiss.
I also discovered that both of my keys I have for this car are valet keys, so they don't open the passenger door or the hatch. Gonna have to get the code off the door lock cylinder to get a new master made.
6/17/13
Took the lock over to McGeorge and got a new key made. Holy balls my keys were worn as hell check this out. It was even starting to crack. One or two more unlock attempts and it would be snapped, stuck in the lock. The key opens both front doors, but the hatch lock won't turn. I'll have to remove the cylinder and grease it up or something, later.
6/18/13
I got the input shaft seal and bearing cover gasket put in on the W58. The output shaft seal was quite a bit more difficult. The one IN the transmission was a little different design than the part I got from Toyota, I guess it was updated over time. The one in the transmission was a metal outer shell (maybe brass?) with a rubber inner seal. The new one was all rubber. I had to pretty much destroy the old one getting it out with my slide hammer.
6/19/13
I got 99% of the intake side stuff disconnected. Two fuel lines left on that side, plus the starter cable, then off to the exhaust side, then the radiator, and then it should be about ready to go.
6/20/13
Fe came up with the name of the car today. The car's name is Joby, after this magnificent video.
http://www.youtube.com/v/7cqOEr_yfak
The plate shall be "AWW JOBY"
Anyways, I got everything else disconnected and the engine is basically 4 bolts away from being ready to come out. Since I don't have a hoist, I decided to clean up some of the more visible bits of the engine. This thing is probably the dirtiest engine I've ever seen.
So I took a tupperware container and threw in some water and simple green and some friends and I scrubbed the two intake manifold bits, valve covers, throttle brackets, and fuel rail until they were thoroughly degreased.
So then later this evening I got all the paint off the valve covers and prepped them for paint. Here's how they turned out:
And here's how the engine sits right now.
6/25/13
6/26/13
Picked up 5 P-type wheels, four need elbow grease, all need tires.
7/2/13
I got the head off and apart today. Man this thing is different from anything I've worked on so far. Each cam is held in it's own cam tower, a separate piece from the head. This thing also uses rocker arms and hydraulic lifters which is not something I've ever messed with. Also, my valve spring tool thing I used on the 7M is too small for this motor, so I am ordering a different kind of spring compressor the guys on CelicaSupra use from Amazon:
Also, I'm going to pull all the lifters and make sure they're all good and clean them out using this process:
Suprabee wrote:
Howdy, during my recent project having a full valve job done, I serviced my lash adjusters. Here's my pictorial of the process for those of you new to our lash adjusters.
After removing them from the head, which can be difficult sometimes. Generally they can be pulled by hand using some twisting action to free them from the head. If you have to use a hand tool to grab them wrap with cloth to keep from damaging the adjuster head.
Summary Process: The adjuster piston is freed up and allowed to move at its normal operating distance by loosening and removing years of old oil sludge by repeated steps of flushing with cleaner and compressing in a vice.
You should be able to compress the adjuster by hand by the amount shown below. Note: photo is of a cleaned adjuster. All of my adjusters were froze and would not initially compress by hand. Also, my adjuster have 140k miles on them and have seen very regular oil changes, so odds are most, if not all, of your adjuster will also be stuck and not compress properly.
http://img.photobucket.com/albums/v317/ ... MG1383.jpg
Step 1) I used brake cleaner, but carb cleaner will work fine too. Hold the adjuster away from you and spray into the side hole as shown below for a second or two allowing cleaner into the cylinder and make it ready for the next step.
http://img.photobucket.com/albums/v317/ ... MG1373.jpg
here's what came out:
http://img.photobucket.com/albums/v317/ ... MG1385.jpg
Step 2) compress adjuster using vice. Note: on this first compression step, it may be very difficult to compress the sucker, but don't worry, you won't crush it. Compression I found on this first step was usually only a couple millimeters.
http://img.photobucket.com/albums/v317/ ... MG1374.jpg
Step 3) Spray again with cleaner as in Step 1
http://img.photobucket.com/albums/v317/ ... MG1381.jpg
Step 4) Compress again in vice. It should be easier to compress at this point, and basically you keep repeating the flushing and compressing until no more black shit comes out and you can compress the adjuster its full distance. My adjuster took 4 steps to complete the cleaning/freeing up process:
http://img.photobucket.com/albums/v317/ ... MG1377.jpg
http://img.photobucket.com/albums/v317/ ... MG1382.jpg
Another pic showing the range of adjuster movement:
http://img.photobucket.com/albums/v317/ ... MG1370.jpg
If you have trouble pinching then adjuster with your fingers try it this way. When fully cleaned and freed up, the adjuster should "bottom out" with not much force
http://img.photobucket.com/albums/v317/ ... MG1392.jpg
Step 5) Ready to bleed the adjuster. Use a light viscosity oil. I used 5w-30. Submerse adjuster completely in oil. Cut a piece of a clothes hanger, or small Allen wrench, or something similar to fit into the hole. Compress the ball and spring in the bottom of the adjuster. Feel around for the ball and press down and up repeatedly to allow oil into the chamber below the metal ball/spring. Air will bubble out of the top. Do this until no more air comes out.
Also, found here:
http://www.cygnusx1.net/Supra/Library/TSRM/MK2/manual.aspx?S=EM&P=32
http://img.photobucket.com/albums/v317/ ... MG1415.jpg
http://img.photobucket.com/albums/v317/ ... MG1416.jpg
Lash adjuster is ready to be installed back in head in the same location it was removed from...And I always match up the hole on the side of the adjuster(that you sprayed cleaner into) with the oil feed hole on the side wall of the head. Not sure if this matters that much, but I do it anyway.
Rick
Later 7/2/13
The lifters are REALLY hard to get out of the head. And I broke one. No idea how that's coming out of there. When I got the others out, they all came out in two pieces. The inner piece with the ball on top came out, then I would have to get the outer housing out of the head, which made cleaning them out very easy. Now I just gotta get one new one and pray that the machine shop can get the remains of the broken one out of the head.
Later-er 7/2/13
After doing some searching, apparently having the lifters come apart is bad. Also, RockAuto has SealedPower lifters on massive sale ($10 instead of $60) so I'm just replacing all of them anyway. Also in that order are spark plugs, plug wires (the ones that came off are wicked old and the ends are pulling off), and dizzy cap/rotor.
7/3/13
Dropped off the head and flywheel at the machine shop. Flywheel is getting resurfaced, head is getting resurfaced + valve job + broken lifter removed. They told me that the labor for putting in new stem seals is included in the valve job, so I can bring them my seals and they will put them in for me. So basically the $20 I spent on that valve spring compressor tool was kinda a waste.....
 Post subject: Re: 1986 MX72 Cressida Wagon Build: "Joby"
PostPosted: Thu Jul 18, 2013 3:38 pm
More build stuff:
Ordered the following from RockAuto:
87 Supra Aisin clutch slave cylinder
87 Supra Dorman clutch alignment tool
87 Supra Clutch release bearing
87 Supra Clutch pilot bearing
84 CelicaSupra Beck/Arnley clutch master cylinder
Ordered the following from DriftMotion:
full length clutch hose
W58 pressure plate bolts
ARP 7M flywheel bolts
ARP 7M head studs
12x1.5mm tap
Today, I wire-wheeled, painted, and installed the AE86 clutch pedal, as well as degreased the engine block and W58.
Yesterday I got the oil pan and front block plate on, as well as the timing belt drive gear, oil pump gear, timing belt idler pulley, front main seal, and oil pump shaft seal. Here's how the engine sits now
7/10/13
Got two more wheels mostly prepped today (with help from a friend), washed the engine bay, and bought supplies for painting the wheels, metal for making EGR blockoff plates, etc.
Also took the driveshaft over to the NAPA machine shop to see if they could elongate it. They said because of the way some Toyota and Nissan driveshafts are made, the U-Joints are not serviceable/replaceable so they can't do anything with it. They instead referred me to Standard Parts down near the Maury St exit off 95. I took it over there and they said they can't modify the one I have, but they can make me a brand new one with serviceable joints to my specs, but it would likely cost around $350-$400. This may be my only option.
7/17/13
Mother of sweet little baby Jesus I need this in my life....but so much moneyyyyyy
http://www.youtube.com/watch?v=B09_I5pXdEU
http://www.youtube.com/watch?feature=pl ... 2etxwvMAis
$450
http://img.photobucket.com/albums/v346/ ... C_3356.jpg
$200
http://img.photobucket.com/albums/v346/ ... C_3625.jpg
$290
http://img.photobucket.com/albums/v346/ ... C_3492.jpg
Plus the custom work it would take to connect all those things together. But holy crap that sound!!!!
7/18/13
Got the driveshaft back. It's purdey. I got it made at Standard Parts over at 500 Commerce Rd, Richmond, VA ‎(804) 233-8321
The front U-joint is a beefy replaceable "american type", the rear U-joint is a less-beefy-but-still-better-than-stock replaceable "newer Toyota type". The old shaft is 54.5" long, the new one is 58" long since the W58 manual trans is 3.5" shorter than the stock auto.
My package from DriftMotion came in today as well. Contents:
ARP 7M-GTE head studs (5/6/7M can all use them)
DM braided steel full-length clutch hydro line
New pressure plate bolts
ARP 5M/7M flywheel bolts
Tap for chasing the cylinder head bolt threads in the block
I should be picking up the head and the flywheel from the NAPA machine shop tomorrow
PostPosted: Thu Jul 18, 2013 7:25 pm
OK I'm trying to go over the neutral safety/reverse switch wiring in my head and this is my best guess at this point:
OK so the plug pinouts in the BGB are for the plugs on the transmission (which is gone now). I have copied them and flipped them (the bottom ones) to represent the plugs in the harness that the trans plugs went into.
So essentially my understanding is that to start the car the computer has to think it is in either Neutral (N) or Park (P). In order to make the comp think it is in N or P, pins "B" and "N" in the left-hand plug (Plug 1) must be connected. Simply shorting that connection with a bit of wire should allow you to start and drive the car.
However, now the computer permanently thinks it's in P or N all the time, disabling cruise control. I was thinking that if you ran those connections to the clutch pedal switch so that you have to push the clutch to start the car, and that also allows for cruise control to disable when the clutch is pressed.
Alternatively, you would wire it to a switch in the cabin, you can then toggle that P/N connection on and off. Have one switch position labeled "Start" and one "Cruise". "Start" position would be a complete circuit, tricking the car into thinking it's in P or N, allowing you to start the car. "Cruise" position would be an open circuit, making the computer think it's in D, and allowing the cruise control to work.
Next issue is reverse lights
The plug coming out of the W58 has two wires in it, and I'm GUESSING that the way it works is when you put the trans in reverse, it completes a circuit. So basically all you'd have to do is connect pin C on plug 2 to one pin in the trans plug, and pin R in plug 1 to the other pin in the trans plug.
This is all just me looking at diagrams. I have no idea if this actually works.
PostPosted: Fri Jul 19, 2013 7:40 am
Very cool. Makes me want to work on mine this weekend.
PostPosted: Sat Jul 20, 2013 8:13 am
Got the head and flywheel back from the machine shop yesterday!
I chased the threads in the block with the tap from DriftMotion and put the ARP studs in
And the head is on!
The only weird thing about using 7M studs on a 5M is that the 7M studs are a hair too short, so basically you thread them into the block as far as they will go tighten them hand tight, put the head on, install the washers and nuts finger tight, then "loosen" the studs so they have more threads in the nuts. I made it so there is one unused thread in the nuts, I feel as though this is adequate threading for both the nuts and the block. Then torque it down in sequence in three equal steps up to 90 ft-lbs. My torque wrench only goes up to 75 unfortunately, so I just did up to 75 plus 30* or so.
PostPosted: Sat Jul 20, 2013 7:47 pm
How the engine sits tonight before I go out of town for the week. It looks like a real engine again!
PostPosted: Sun Jul 21, 2013 1:10 am
nice work!
driversity.tumblr.com
PostPosted: Fri Jul 26, 2013 7:00 am
:tu: love the wagons!!!
PostPosted: Mon Jul 29, 2013 7:31 pm
Got a bunch of little things done today after work.
Clutch master cylinder has been bench bled and installed (yeah one of the bolts is wicked long. It's all I had at the time. Sue me)
I also connected up the clutch line and slave cylinder and bled the whole thing on the bench, so the hydraulics are ready to go.
The old throwout bearing has been pressed off the hub and the new bearing has been pressed on and everything is greased and ready to go.
I also took a peek inside the brake reservoir, just to check the fluid since the pedal went straight to the floor on the test drive. This is what I found:
It is growing algae. My brake hydraulics have become a freaking ecosystem. I sucked out all the fluid in the reservoir and it was SO nasty and completely opaque:
The system is going to need to be flushed for a good long while before the car moves anywhere.
I don't have a pic, but I also got some wires soldered to the terminals on the clutch safety switch. That will go in tomorrow, and will be wired up after the engine is in the car.
Parts I still need to order:
clutch fork boot
thermostat
fuel filter
PostPosted: Mon Jul 29, 2013 7:52 pm
Hell yea boss. Wagons ftw!
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
PostPosted: Wed Jul 31, 2013 8:22 pm
I got my MA70 speedo cable, clutch safety switch, and driver's side interior installed/put back together
right now my problem is this:
Snapped a bolt in the thermostat housing. I tried soaking it in PB blaster, vicegrips, slotting it and using a screwdriver, and a bolt extractor. The extractor bit snapped off inside the pilot hole in the bolt. Whatever metal the extractor bit was made of is too hard for my designed-for-drilling-metal drill bits to even scratch, so I can't even drill it/tap it. I think getting another housing from either CelicaSupra forums or junkyards is the only way forward.
PostPosted: Wed Jul 31, 2013 10:40 pm
Nice keep it up man
77 TE51
PostPosted: Fri Aug 02, 2013 9:46 am
Hit that broken fastener with a mig welder, allow to cool, then they usually wind right out.
Isaac
PostPosted: Sat Aug 03, 2013 7:45 pm
8/1/13
Went to CAP (woodfin) and pulled the windshield trim (for Mitchell), both seats, and thermostat housing off of the MA60.
8/3/13
Supra seats don't fit, rails are wrong.
I finished my EGR removal today. Fabbed block-off plates and gaskets, blocked off vacuum lines, etc
I also made wiring for the clutch-activated neutral safety switch and the reverse light switch. As soon as my new silicone couplers for the intake piping come in (the stock ones were super split), the engine will be ready to come off the stand, have the rear main seal replaced, clutch/flywheel bolted up, trans bolted on, and put back in the car. I'll be putting Redline MT-90 gear oil in the trans, and I'm going to run wal-mart brand oil in the motor for a day or two, then change it out for some Amsoil. The cooling system will also be getting Amsoil coolant boost that I had left over. I still have to drop the rear axle and change all the seals, but I'm not sure when that will happen.
PostPosted: Sun Aug 04, 2013 12:41 pm
Picked up the hoist from a friend's place and removed the motor from the stand.
New rear main seal
Installed pilot bearing and got the clutch disc ready to go
This is when I noticed that the flywheel's friction surface was a little bigger than the clutch disc. No biggie, just weird. But when I went to put on the pressure plate, the bolt holes/dowel pins on the flywheel don't line up with the holes in the pressure plate. I googled 7MGE and 7MGTE flywheels and concluded that I have two 7MGE clutches (which is what I need, so good) and a 7MGTE flywheel.
Awesome. Well I called the guy I bought the stuff from and he said he knows he has for sure some more NA flywheels buried in his garage but it will be some night this week before he can get to them. So I can't put my motor in till I have this crap taken care of, and I'll still be out the gas money to go get the parts from Fredericksburg AND the $55 I spent resurfacing the one I have. I could seriously punch a baby right now.
PostPosted: Tue Aug 06, 2013 7:05 am
M engine problems.
PostPosted: Tue Aug 06, 2013 2:21 pm
Starting to get parts in the pipeline for a brake system refresh. It has hubbed front brakes and rear drums, so none of it will be easy or simple to do. Here's a pic of how old school Toyota front hubs work
So it's rotor, seal, bearing, hub, bearing, claw washer, nut, castle cap, cotter pin, axle cap. I ordered new seals, bearings, claw washers, and cotter pins from Toyota. Pads, rotors, drums, shoes, and wheel cylinders are being ordered from RockAuto. I don't think it needs calipers or lines, but if it does I'll either rebuild or replace the calipers and probably come up with some custom stainless lines.
PostPosted: Tue Aug 06, 2013 2:31 pm
You should just watch Rockauto. I picked up fully loaded front calipers for right around 10 bucks a bit ago. They tend to go on clearance all the time there. Also, the easiest way to get the rotors off is to mount them in an upside down wheel. Have a friend stand on the wheel and then hit them with a 1/2 ratchet or breaker bar. Mine were a bear to get loose, but once the bolts cracked, they came right off. Oh yeah, the rotors will come off without taking anything else with them. They don't hold the bearings or seals in.
One more addition, Rockauto also has brake lines on clearance all the time as well. I spent under 100$ getting all new calipers, rotors, shoes, cyclinders, drum brake hardware and hoses just by watching the clearance stuff.
Here is the link for the cressida clearance stuff
http://www.rockauto.com/RSS/vehiclefeed ... &html=true
1985 MX72 soon to be...
PostPosted: Tue Aug 06, 2013 3:05 pm
So basically use a jaw puller to remove the hub/rotor as a unit from the spindle then use the upside-down wheel trick?
PostPosted: Tue Aug 06, 2013 3:37 pm
Yeah, you shouldn't even have to use a jaw puller. I just whacked it... okay. just tapped it with a rubber mallet and off it came. It shouldn't be jammed on there hard. Also, make sure you you preload the hub right. Here are the pages from the Toyota service manual.
Replacing the rotor disc
Preloading the axle bearings
Here are the pics that accompany those directions.
