It is currently Mon Jul 06, 2015 3:11 pm
Post a new topicPost a reply Page 1 of 2   [ 24 posts ]
 Post subject: JZX32 Toronto Canada
PostPosted: Thu Jul 18, 2013 12:28 am
Here are some pics of my car
2jz VVTi and 5 speed swap, front coilovers, camber plates, Audi TT front seats, all new bushings, 4 links,
secret one of a kind bumper swap to rid myself of the scourge of the hideous park benches that molest every North American x3 :lol:
everything supension steering new
Love driving it....x3 FTW
.... some decent photos
Uploaded with ImageShack.us
 Post subject: Re: JZX32 Toronto Canada
PostPosted: Thu Jul 18, 2013 7:32 am
wow! nice looking cressida :tu: :tu: :shock: :twisted:
PostPosted: Thu Jul 18, 2013 7:38 am
daaaaaaaaaamn. did you build it yourself or buy it swapped? how about some details?
PostPosted: Thu Jul 18, 2013 9:16 am
Looks damn fine. Super clean bumper swap. Love the work equips on these cars too.
PostPosted: Thu Jul 18, 2013 10:43 am
Why super secret bumper treatment? Share with the community and let it grow!
Good looking car, do you have engine bay shots?
Love the white lettering on the tires gives it a "race" look.
1980 Cressida MX32
Old Series Garage
PostPosted: Thu Jul 18, 2013 12:41 pm
I swapped it myself, here are some basic details, I will answer any specific questions that anyone has, the hardest part was the wiring ;)
- I used a JDM vvti engine.....these have no immobilzer, if you can't source a JDM one, better stay with an older 2jzge
- I had to join a Japanese auction website and imported a JDM ECU as the ecu I got with my engine was a North American one (bastards at engine place....but I was a newbie when this process started and didn't know it was wrong ecu)
- wiring diagrams for JDM 2jzge vvti are only in Thai, located here: http://gallery2.plebeians.net/v/cars/su ... -i_1_.jpg/
had to study these for awhile, and look up all abbreviations etc. to make sure what was what
- engine mounts from excessive will work (x7 jz mounts) as the block from any m series engine is the same
- I used ones for a jz mk3 swap that I got off of ebay before I knew of the excessive mounts, and had to buy two sets because the mounts weren't symmetrical, then I cut and welded them at an angle to sit the engine 2" farther back. With the excessive mounts you can avoid all that ;)
...to be continued
PostPosted: Thu Jul 18, 2013 12:56 pm
so nice and clean under the hood. :tu:
1980 Cressida MX32
Old Series Garage
PostPosted: Thu Jul 18, 2013 2:27 pm
and the bumper?
PostPosted: Thu Jul 18, 2013 3:21 pm
Mr. Clean, What radiator is that?
1985 Dodge Ram 50(soon to be drifter)
1980 Toyota Cressida(Daily)
PostPosted: Thu Jul 18, 2013 4:16 pm
Rad is a universal Mishimoto one with the inlet(top) on the drivers side and outlet(bottom) on passenger
Everyone knows JDM spec bumpers are impossible to get.....so I just looked at what was available, old american car bumpers from the 60s that had the shapes I was looking for. I just cut and shortened them and welded the brackets.....easy. ;)
I used a w58 from an mk2, and with the engine as far back in the bay as I could get it (valve cover like 1/2" from firewall)...the trans bolted up using stock trans cross member, and shifter in stock hole. Lucky.
Luckily, the JDM 2jz uses a return line on the fuel rail, so I just ran new braided fuel line to an aeromotive stealth fuel cell w pump inside and mounted that in the trunk after taking out the old tank. I didn't want to deal with keeping the non baffled old tank at least a 1/4" full, or redoing the stock tanks sending unit with new lines for high psi EFI....too much hassel.
Xerd/Mazzurri header that was custom fit because the collector was interfering with the idler arm so I cut and rewelded it so it angles closer to the engine/trans.
T3 camber plates and weld-on coilovers, .....eibach circle track race springs in the rear (350lbs was the lowest stiffnes they came in). Camaro AGX short stroke in the rear and MR2 short stroke in the front shortened struts.
Added a clutch pedal from an is300....gas pedal from an MR2, and had to find an extra long throttle cable used in some ae86s in order to reach the JDM throttle linkage as its on the passenger side....
Did an AC delete....powersteering is hooked up.....6 componeant speaker and 2 amps with sub and kenwood iphone deck...sounds nice ;)
Thats all I can think of for now....like I said, any specific questions you have I can try and answer with more details.....thanks for all the positive comments.
Another good guy to ask about this swap is Lloyd...aka Zombie Cressida...although he got a vvti from a friend and was able to get around immobilizer because he also got the steering column transponder as well to make it run....
Like I said before...interms of ease, the earlier 2jz is much easier wiring swap....although the vvti is nice and torquy !! ;)
PostPosted: Fri Jul 19, 2013 5:17 am
so tidy! very well done mate, props on the build.
Mitsubishi Starion Turbo 83'
Toyota Cressida 77'
Toyota Cressida 78'
Mitsubishi Galant 75'
PostPosted: Fri Jul 19, 2013 10:10 pm
holy moly! i love this thing :) what size wheels are you running as i want mine to fit like yours.
PostPosted: Fri Jul 19, 2013 11:21 pm
9x15 -40 in the rear....(but that won't fit on stock rear axle)
9x15 - 15 in the front with rolled fender arches
Tire size I thought and planned on alot....googled for months (Tyrestretch.com is your friend ;) )....
finally decided on 205 R50s and couldn't be happier :D
PostPosted: Fri Sep 20, 2013 5:55 pm
Made a custom grille out of my spare one :D
PostPosted: Thu Dec 05, 2013 12:26 am
hi,i got a JDM 2JZGE VVTi coming from a Toyota Progres but it has an immobilizer on it..so i have to buy EMS to get rid of it..:(
PostPosted: Thu Dec 05, 2013 7:13 am
PostPosted: Thu Dec 05, 2013 7:19 am
Strange that a JDM one would have an immobilzer...?
Are you sure the engine/ECU/EMS is JDM?
As far as I know.....Japan didn't use immobilzers because car theft there isn't as common because the penalties are so severe if you get caught.
I would take a peek at your ECU/EMS # and do some googling to find info on that model...
When I bought my engine, it was a JDM 2jzge vvti but they didn't give me a JDM ecu that went with the engine....but a newer ecu that went with, I think an is300 or something....so it never worked.
I had to join some Japanese auction sites and import a real JDM ecu that went with my engine.
Not saying that's your issue....but it is a possibility ;)
PostPosted: Fri Dec 20, 2013 4:19 pm
Hi,here's the ecu part number that comes with my JDM 2jzge vvti -89661-51010 coming from Toyota Progres..what appropriate ecu should i get for this JZ engine,if you have part number,that would be better:)tia
PostPosted: Fri Dec 20, 2013 9:02 pm
if you could provide a pic of the engine and the ecu (plugs) it would help alot...there are many variations of the 2jzge vvti...and they all take a different ecu...can't tell anything without photos
PostPosted: Wed Jan 01, 2014 6:34 pm
hi, here's the engine 2JZGE VVTi from 2002 JDM Toyota Progres'
and here's the ECU pictures for your reference
inside pic of the ECU
thanks...
Users browsing this forum: 02Anders and 2 guests
