It is currently Sat May 23, 2015 7:58 am
 Post subject: 78 TE31 gas tank o-rings/seals
PostPosted: Mon Jul 01, 2013 8:24 pm
Where can I get the orings for the gas tank?
Looks like two are the same size (fuel sender and filler neck), and then
the main gas feed/vent at the top is slightly smaller.
Please don't say "go to a parts store". I actually work in auto parts and have searched high and low at my store, plus my competitors with no luck.
Everything is either the wrong ID/OD (and ends up leaking, or breaking the O-ring from being stretched), or is too thick (cross section) so I can't get the lock ring in place.
I found one that I *might* be able to make work for the gas feed at the top, but not the others.
Does anybody know what the exact dimensions of these should be? ID/OD and cross section.
Please advise guys! I know someone has replaced these things!
 Post subject: Re: 78 TE31 gas tank o-rings/seals
PostPosted: Sun Jul 07, 2013 10:48 am
Try searching around on this site...
http://www.toyotapartszone.com/Page_Pro ... 5=MTM;6=4F)&originCountry=(10=USA)&sectionID=&componentsID=77-01
1997 Audi A4 2.8 Quattro 5 Spd
1977 Toyota Corolla TE31 4 Spd. - Build Thread = viewtopic.php?f=9&t=22584
PostPosted: Thu Jul 11, 2013 9:27 pm
The original parts are non existent. I tried ordering them through a friend that works for Toyota before I made this post.
I ordered a bunch of similar sizes online and tried them all. Found some that work.
For future reference and searchability:
http://Www.theoringstore.com
#B70331 x 2 (please note you have to order at least 4, though, as the manufacturer has a minimum order on each number). This size works for the filler neck and the sender.
#B70329 x 1 (again, you'll see a minimum but they're ridiculously cheap). This size works for the center/top feed/return line unit.
Hope this helps someone in the future.
