It is currently Sun May 24, 2015 12:34 am
 Post subject: Diff / axle info needed.
PostPosted: Mon Jul 08, 2013 5:12 pm
I have a 1976 corolla with a 2 pinion, 6.38" diff. 4:10 ratio (stock). I want to know if a 1981 4 pinion, 6.38" diff with a 3:583 ratio will fit.
Are the axle shaft splines the same?
 Post subject: Re: Diff / axle info needed.
PostPosted: Mon Jul 08, 2013 9:19 pm
All 8 bolt S type 6.38 use the same axle spline number and dia. It'll bolt on like stock no problem... only question I have is why? Why go from a nice 4.1 to a sloppy 3.58?
2003 Toyota Celica ZZT230 (Daily)
PostPosted: Tue Jul 09, 2013 11:46 am
Currently I have a A40 auto in the place that my t50 will eventually fit. Freeway speeds on 185/60r14's revs a bit high for my liking. After I get the 5 speed in ill probably go back to the low ratio or something in between. Thanks for the info.
PostPosted: Tue Jul 09, 2013 9:31 pm
Pumpkin will fit but driveshaft flange may differ. Bolt up kitty corner with only two bolts (I have seen people race with slicks with only two bolts) or you can drill the other two holes. I drill my pumpkin flange with the driveshaft on and never had any problems. You might be lucky and it will match, I forget the year that it changed over.
