It is currently Sat Apr 18, 2015 1:52 am
 Post subject: KE30 or TE31 measurements request
PostPosted: Mon Jul 01, 2013 11:19 am
hi. can anyone with a TE31 or KE30 kindly measure their front windshield rubber seal for me? I'm trying to determine if I can use this on a Te51 and what level of modification, if any, would be needed to use this.
I would REALLY appreciate it.
dang TE51 seals are a b!tch to procure as some of you know. I just know there has to be a warehouse of NOS ones somewhere just sitting in a pile.... sigh...
 Post subject: Re: KE30 or TE31 measurements request
PostPosted: Mon Jul 01, 2013 6:39 pm
22, 43, 54
That is measuring the middle of the seals.
PostPosted: Mon Jul 01, 2013 7:57 pm
Thanks Skellington!
That's with locking strip, correct? and the outer edges overlap/are thicker more towards the outside?
I measure roughly 54 along the bottom, center to center and 43 along the top roughly from the center of the seal on each side but it looks like the TE51 may be taller. I measured roughly 24" from top center of seal to bottom center of seal. That was from the center.
Did you measure your 22" on the edge of the windshield or in the center between the wipers?
thanks again!
PostPosted: Mon Jul 01, 2013 10:16 pm
22 was measured on the edge.
PostPosted: Tue Jul 02, 2013 6:47 am
thanks! this helps tremendously and I suspect this will help others in the future when they search for similar questions.
