It is currently Tue Jul 07, 2015 5:22 pm
Post a new topicPost a reply Page 2 of 3   [ 46 posts ]
 Post subject: Re: 1973 TA22 Toyota Celica.
PostPosted: Thu Nov 28, 2013 10:56 pm
Toyohead wrote:
Those new items are not my taste as the custom chairs but further a nice celica. How is the steering rack and pinion performing compared to the stock version?
The rack and pinion is so much better, a lot more precise. no more slack.
PostPosted: Sat Nov 30, 2013 2:01 pm
Ah thanks. Maybe my carina wich is not getting a lot of attention here from JNC forum will be converted to rack & pinion also in time.
Have the old steering housing and ball bearing surfaces refurbished and adjusted, it feels very tight now when wheels are in driving position.
Slack happens indeed in R or L steering. We'll see :)
Oh and i do al lot myself too, mof allmost everything such as the new vinyl on chairs/dashpad/rear window trim and more.
Good luck with further steps on your Celica!
PostPosted: Sun Dec 01, 2013 4:24 pm
I fixed the seat in the Celica. I pulled the cover off the top of the seat and glued more foam in to bulk it out. Now the cover fits tightly over the seat and looks like the other one.
PostPosted: Wed Dec 18, 2013 2:41 pm
The other day I started work on the seat belts to tidy them up and make a box around them, when disaster struck, I smashed the plastic cover on the side that holds the coiled spring in place. In other words the seat belts are now in the bin and can't be fixed.
But then something good, my bro was coming to town and he said I could have the seat belts out of the Honda Integra that he has wrecked. So I am in the process of making them fit and making a box that will fit nicely around them.
PostPosted: Wed Dec 18, 2013 2:42 pm
I got the Integra seat belts of my brother the other day, I unstitched the bottom bracket and took all the Honda brackets and clips off the belt then put all the toyota stuff back on. Then stitch the bottom back up, Hay presto working seat belt again. Just making the cover to go over the top of the body of the retrackable part then they are finished.
PostPosted: Wed Jan 01, 2014 5:18 pm
I have just ordered T3 camber tops and panhard rods
PostPosted: Thu Jan 02, 2014 1:48 am
:D :D :D :D :D :D :D :D :D
PostPosted: Thu Jan 09, 2014 2:10 am
Look what turned up today
It's a pitty that the cambertop will be shelved until I can afford coilovers. :(
PostPosted: Fri Jan 10, 2014 4:18 pm
I decided to put the rear panhard rod In this morning, but as usual something f*#ked up. The panhard rod on the diff end needs the shaft that runs through the original bush, so I started to push it out but it was bullshit tight. I did get it out but is now destroyed, so I have to get a new one made, up just more money I don't have!!!! Also in the process I smash the hammer into my hand, Should have stay inside.
PostPosted: Fri Jan 10, 2014 7:14 pm
I went back up to the shed to have a look at the shaft and decided it wasn't that bad after all. I straightened It up and sanded the edges off and it slipped into the heim joint hole. So I bolted the panhard rod up to the car. The diff is now centered, but there is no more adjustment so that was lucky. But there is a problem, the rod hits the back of the diff housing if I go over a decent bump. I will have to space out the diff mount so it sits out a bit more.
PostPosted: Sat Apr 05, 2014 10:41 pm
I have ordered these from T3 .......
PostPosted: Fri Apr 11, 2014 6:42 pm
So my 4 link control arms from T3 came yesterday, and today I have put them in the car. What a difference, The car feels so much more controlable, and planted on the road. The noise of the diff and the road are a little more than normal. Overall, very happy with them. The only thing now is to put better tyres on with stiffer side walls. My cheap ones that are on the car now are all over the place.
PostPosted: Tue Jun 10, 2014 12:56 am
So I bought these goodies......
I cut down my spare struts to make the coilover....
Then fitted them into the car....
Then set it at maximum camber for this result.
Then some new stickers....
PostPosted: Tue Jun 10, 2014 11:54 am
is the trim around the lower valance factory?
- Travis
Bunch of cars, All TEQ Branded.
PostPosted: Tue Jun 10, 2014 10:46 pm
No It is the plastic chrome that pushes on to the edges of doors.
PostPosted: Tue Jan 13, 2015 6:37 pm
Been a while whithout updating. Not much has happened. I have painted my rear flat tail lights to USDM, I use model car tail light candy red that you can buy from any model shop.
I painted in on with my finger then wet sanded and polished to get it smooth.
I will repaint them with a spray gun as I got one for Christmas.
Also I pulled my diff out, as I stuffed up by replacing the front seal and not replacing the front crush bearing. Now there is no preload and it was getting noisy. But pulling it out found other problems. The shockies where stuffed as was the brakes. So I have rebuilt the brakes, and bought Holden shockies that are 60mm shorter than the factory ones.
But the big news is this.........................................
Thats right a 20 Valve 4AGE.
I have total stripped it down and have found it has had water sitting in it for some time. So a total rebuild is in order. The plan is to build a full Tomei engine, top to bottom. I will be keeping it N/A, with an After market Computer.
PostPosted: Tue Jan 13, 2015 7:41 pm
:tu: :tu: :tu: 20v good choice
PostPosted: Tue Jan 13, 2015 9:59 pm
A complete Tomei build! Can't wait to see that
Please post a video of the engine running at the end of it all!
kolxoz
PostPosted: Wed Jan 14, 2015 3:56 am
This will be a very slow build over several years as cash is tight at the moment, so you will all have to be patient.
PostPosted: Fri Jan 16, 2015 1:58 am
I cleaned the inside and the outside of the Throttle Bodies today, they look heaps better.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 8 guests
