It is currently Sat Jan 24, 2015 9:01 pm
 Post subject: mx62 Big Booty
PostPosted: Mon Oct 13, 2014 1:40 am
hey guys well after I seized my 7mgte in my mk3, Iv been on the hunt for a new daily.
well yesterday I found a x62 wagon for sale for 1k in SF
well let me tell you it made it home no problem! :)
this will be my second wagon.
here was my first
same plans As I did with the old one, but insted of a 7mgte swap
Im taking all the turbo components off the 7mgte and putting on the 2.8 5mge
and mix with some of my 7mge parts, going to make a 6mgte. :)
7m bottem end, with a 5m head and the ct26 turbo, run on low boost with the 295cc yellow injectors from a 7mge.
going to make a set of coilovers for the front, T3 DIY kit, t3 camber plates, mr2 agx shocks and extended LCA's and modded knuckles.
Rear end: welded Diff, Camero Agx shocks and custom springs in the rear cut, with spring perch adjusters and a T3 Pan Hard bar.
Wheels: on my old setup I have 195/55 on a 15x10-25
Now this time Im thinking of a 175/55 on a 15x10-38
Now I just need to start saving for parts![/QUOTE]
[QUOTE=mitchbrock1;1355695]well today I picked up some p-type's for 100$ and cut my springs and it rides great! yes iv had coilovers before.
but I only cut 2 1/2 coils all around and I found out it has agx shocks lol...
(minor update)
new paint coming soon, and some turbo action!
Image[/QUOTE]
[QUOTE=mitchbrock1;1370538]Image
well replacing all the old crap from under.
picking up t3 DIY kit from a buddy with ae86 camerplates and NCRA's (dont know if they fit. but if I remember right the strut casing's it self is the same model numbers.) for 300$ total. :)
then next check ordered some custom metal flares from SSauto Power.
and ordering some wheels from diamond racing since im ballin on a budget.
15x10-51
or debating on 15x10-76
most likely with go with 15x10-76[/QUOTE]
[QUOTE=mitchbrock1;1370539]it was a toyota kind of day :)
Image[/QUOTE]
[QUOTE=mitchbrock1;1372059]Image
bringing my paint back to life.
lots of new parts. still more to come.
skirts?..... some random skirts I found in my backyard when I moved into my house 4 years ago.[/QUOTE]
[QUOTE=mitchbrock1;1373546]Image
well im pumped!
NCRA's!, weld on kit, and camber plates!
next is shocks and wheels!
stay tuned![/QUOTE]
[QUOTE=mitchbrock1;1374172]So today got some work done, I called T3(techno toy tuning) and im able to swap out the ae86 camber plates and NCRA's for the Cressida's models.
a 84 wagon with 230k, and this is the worst/dirtiest car iv ever worked on.
that lip is dirt/grease mix.
so part list so far.
*outer tie rods,
* inner tie rods,
* tie rod sleeves,
* wheel seals,
* sway bar bushings,
* sway bar links,
* Lower control arm bushings,
* T3 camber plates,
* 12kg eibach spings,
* T3 weld on kit sleeves,
* T3 Negative center roll adjusters.
Image[/QUOTE]
[QUOTE=mitchbrock1;1374461]well Gabe (the owner) of Techno Toy Tuning hooked it up, went up and visted and check out the sweet builds he has going on and changed out the ae86 camber plates with mx61 camber plates and its a new design!
going back tomorrow for the correct NCRA's.
So made a trip yesterday back to T3 (techno toy tuning) factory and Gabe the owner hooked me up!
traded the ae86 Rca's for x6 Ncra's!
-12 camber in front here we come (need to get a T3 Weld on LCRA kit next)
0 camber in the rear.
this was my last wagon with t3 camber plates and 1.5 inch extended lcra's
 Post subject: Re: mx62 Big Booty
PostPosted: Mon Oct 20, 2014 5:48 pm
Nice to see someone doing mods on a mx62. I see you put the x7 front light on. How's it look?
PostPosted: Thu Jan 22, 2015 4:33 am
7mge block-Check
7mge crank-check
7mgte rods
5mge 12v top end-check
81-82 5mge pistons
hks 2mm hg
arp head studs-Check
polish valves
titanium valve springs
stock ct26-check
7mge injectors-check
WinterJam was rad.
pick up some 14kg springs for 20$ (black)
old ones are 7kg.
time to make my coils :)
and got brand new mr2 agx shocks for free :)
guy sold me them, my dad told me they where bad, so I message the guy and boom refund.
guy diddent want them.
I go check them and my pops was looking at the old shocks lol.
15x10-88 ;)
PostPosted: Thu Jan 22, 2015 1:42 pm
Nice! I just got a x6 sedan
Users browsing this forum: n0el and 4 guests
