It is currently Sun May 24, 2015 10:40 am
 Post subject: rebuilt aisan carb on my rt52 and need HELP!!
PostPosted: Mon May 13, 2013 6:34 pm
so... i rebuilt the aisan carb on my rt52 coupe and am having nothing but trouble getting it to run right. no matter how i adjust the float it just overfills the bowl. should i keep screwing with it or ditch it in favor of something else? any imput is greatly appreciated. the weather is nice now and im dying to cruise this thing:(
68 rt52 corona coupe
80 mx32 cressida (sold)
74 maz rotary pickup
88 turbo2 rx7
 Post subject: Re: rebuilt aisan carb on my rt52 and need HELP!!
PostPosted: Mon May 13, 2013 6:40 pm
here is the corona in question
88 turbo2 rx7
PostPosted: Mon May 13, 2013 6:41 pm
Sounds like the needle is not seating. Fuel pump pressure too high? Needle does not have the rubber cone or rubber cone is dried out? Floats not floating? Crud on the needle seat?
PostPosted: Mon May 13, 2013 6:42 pm
how do i adjust the fuel pressure? the needle and seat are new. and i inspected them for debris and it is clean as a whistle.
88 turbo2 rx7
PostPosted: Mon May 13, 2013 7:35 pm
make sure your float doesnt have a tiny hole in it. fuel inside float = no float = always flooded.
My rebuild sheet for my carb came with a specific way to adjust the float bowl. Did you get one of these, and did you follow it?
PostPosted: Mon May 13, 2013 8:05 pm
the float seemed fine but i will re-inspect it. my rebuild kit came wit a measuring card and instructions which i followed the best i know how.
88 turbo2 rx7
PostPosted: Tue May 14, 2013 1:36 am
Check your accelerator pump nozzle it could be blocked.
Users browsing this forum: Yahoo [Bot] and 3 guests
