It is currently Fri Jan 30, 2015 2:33 am
 Post subject: 1973 Corona MKII dash and gauge redo pics.
PostPosted: Tue Dec 18, 2012 1:41 pm
http://3tcgarage.com/viewtopic.php?f=23 ... 8&start=20
 Post subject: Re: 1973 Corona MKII dash and gauge redo pics.
PostPosted: Tue Dec 18, 2012 3:51 pm
Nice job on the dash! I like the touch of the tach instead of the clock. RA29 Tach?
You can probably mount an early MX32 or RA21 clock in your console now.
PostPosted: Tue Dec 18, 2012 8:37 pm
Tack. may have been from 74 celica but i think still same as RA29?
The one with just speedo and tack gauges.
Ya I want to add a clock to console,I have 2 that I tried but too small.I think one was RA21?
Console is now undergoing same process.
PostPosted: Wed Feb 13, 2013 7:42 pm
New headlight pics. 8)
PostPosted: Thu Feb 14, 2013 1:32 am
That's some pretty awesome work. Headlights are a nice touch. Cant wait to see them when they are installed. What are you doing with those rear quarter window louvers? Did you make a cover plate for them or something?
PostPosted: Thu Feb 14, 2013 8:21 pm
Ya unsure which light combo to go with yet,they may be a little much for the car?
Ya i made the cover for the 2 side vents.it bolts on with 3 hidden screws.
PostPosted: Fri Feb 15, 2013 1:30 am
I would love to see how those side vents look. My suggestion on lights.... don't go over the top. I was going to do projectors in mine but try to keep them downplayed not too flashy or crazy as to take away from the looks of the car...
PostPosted: Fri Feb 15, 2013 9:31 am
first, great work on the car so far. When re-doing your dash, what did you do to fix the needles on the speedo and such. All of mine are bent like yours and I would love to straighten them out.
1985 MX72 soon to be...
PostPosted: Thu Feb 28, 2013 2:59 pm
The white needles are metal ones from the rona.The bent one was from the celica tack.
You could try heat pressing yours back to shape then cooling quickly with cold water or air :idea:
I think you could use most any needles from any car if you found a good pair.
I had to add weight to the backside of the tack needle it was too light.
PostPosted: Fri Apr 26, 2013 10:19 pm
Heya, looks awesome!
How'd you get the blower assembly out? I have a 72 corona and from what i see the blower assembly looks similar. I need to change the heater core, blower moter and clean it all up but I'd like to try to do it without ripping out the whole dash. Also, where did you find all the foam insulation strips?
Thanks!!
Larry
-1972 Corona Mark II Wagon-
PostPosted: Tue Apr 30, 2013 12:55 pm
foam is home depot window insulation and a piece from my tap and die kit padding piece.
Foam is everywhere its nothing special,jsut start collecting bits and when you think yougot enough give it a try.
Disconnect 2 hoses and mark your cables where they clamp with a sharpie then remove and clean everyhting.
PostPosted: Thu May 02, 2013 1:01 am
how much did that dash run u?
PostPosted: Thu May 02, 2013 2:13 pm
Man, I contacted Just Dashes and expected it to be spendy, but I didn't expect the quote to be 1/3rd of what I paid for my whole car! Haha.
PostPosted: Thu May 02, 2013 4:17 pm
i found it somewhere its around 1000 bucks.
PostPosted: Wed May 08, 2013 1:59 pm
dash was 1100 and g box door was $200 so i just had them paint the door to match pad.Yes they paint there dashes even though the material is black.
